By NailBuster
#39392
bjpirt wrote:There's also this:
https://github.com/mirobot/mirobot-wifi ... /arduino.c
Which I use to reflash an Arduino using the bootloader protocol over serial. It caches a copy in flash first before writing it to the Arduino and has been pretty reliable. In any case you could use this lib as the basis of what you want to do
Ben
Thanks Ben, I was able to use that as a starting point .....I've now successfully flashed an attached pro-mini via (3 pins) tx/rx/reset using software serial as well!!!
