I'm trying to read pulses to measure the consumption of water, gas and electricity through a wemos d1 mini, along with reading the temperature and humidity with a dht22.
The software does not mistake me, but it does not work, as if it always stops in interruptions.
Can you help me?
thank you all
#include <PubSubClient.h>
#include <Bounce2.h>
#include <EEPROM.h>
#include <DHT.h> // DHT library from http://github.com/adafruit/DHT-sensor-library
// Written by ladyada, public domain
#define DHTPIN 2 // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE, 20);
const char* ssid = "linksys_EXT1";
const char* password = "YourPASS";
const char* mqtt_server = "192.168.1.60";
long previousMillis = 0;
long interval = 60000;
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
const char* outTopic = "home/cantina/stato/output/1";
const char* inTopic = "home/cantina/luce";
const char* outTopic_dht_temp = "home/cantina/temperatura";
const char* outTopic_dht_umid = "home/cantina/umidita";
const char* outTopic_gas = "home/cantina/gas";
const char* outTopic_acqua = "home/cantina/acqua";
const char* outTopic_luce = "home/cantina/enel";
const char* outTopic_luce_imp = "home/cantina/enel_imp";
int gas = 14;
int acqua = 13;
int luce = 12;
volatile byte state = LOW;
//int state_acqua; //the state of the input
//int oldstate_acqua;
//int state_luce; //the state of the input
//int oldstate_luce;
//int state_gas; //the state of the input
//int oldstate_gas;
unsigned long t; //timer
//unsigned long s; //samples
//unsigned long c; //count
//unsigned long f; //frequency
static long p1;
static long p2;
static long p3; //precedente
static long diff1;
static long diff2;
static long diff3;
unsigned long a;
// Instantiate a Bounce object :
//Bounce debouncer = Bounce();
void setup_wifi() {
delay(10);
//Serial.print("Connecting to ");
//Serial.println(ssid);
//WiFi.begin(ssid, password);
WiFi.begin(ssid);
for(int i = 0; i<500; i++){
delay(1);
Serial.print(".");
// Serial.println("");
//Serial.println("WiFi connected");
//Serial.println("IP address: ");
//Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length) {
//Serial.print("Message arrived [");
//Serial.print(topic);
//Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
//Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("ESP8266Cantina_test")) {
//Serial.println("connected");
// Once connected, publish an announcement...
client.publish(outTopic, "py-home-slave booted");
// ... and resubscribe
client.subscribe(inTopic);
} else {
//Serial.print("failed, rc=");
//Serial.print(client.state());
//Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
for(int i = 0; i<5000; i++){
delay(1);
void leggi_dht(){
if(currentMillis - previousMillis > interval) {
float h = dht.readHumidity();
float f = dht.readTemperature();
if (isnan(h) || isnan(f)) {
return;
//Serial.println("DHT sensor read and transmitted");
char buffer[10];
dtostrf(f,2,2, buffer);
client.publish(outTopic_dht_temp,buffer);
//Serial.print(buffer);
dtostrf(h,2,2, buffer);
client.publish(outTopic_dht_umid,buffer);
//Serial.print("Temperature: ");
//Serial.print(f);
//Serial.print("Umidita: ");
//Serial.print(h);
void leggi_acqua()
//diff1
t = millis(); // read time at start of sampling
diff1= t-p1;
if (diff1 >0.1){
client.publish(outTopic_acqua, "1");
p1=t;
void leggi_gas()
//diff2
diff2= t-p2;
if (diff1 >0.1){
client.publish(outTopic_gas, "1");
p1=t;
void leggi_luce()
//diff3
t = millis()/1000;//trasformo in secondi
diff3=t - p3;
if ( diff3 > 0.1 ) { // Se non è il primo blink calcola il consumo
a=3600/(t - p3);
char buffer[10];
dtostrf(a,2,2, buffer);
client.publish(outTopic_luce, buffer);
p3=t;
client.publish(outTopic_luce_imp, "1");
dht.begin();
pinMode(gas, INPUT); // Initialize the gas pin as an input
pinMode(acqua, INPUT);
pinMode(luce, INPUT);
setup_wifi(); // Connect to wifi
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
attachInterrupt(digitalPinToInterrupt(luce), leggi_luce, FALLING);
attachInterrupt(digitalPinToInterrupt(acqua), leggi_luce, FALLING);
attachInterrupt(digitalPinToInterrupt(gas), leggi_luce, FALLING);
if (!client.connected()) {
reconnect();
client.loop();
leggi_dht();
