Explore... Chat... Share...
Pablo2048 wrote:Ok, Plan B... Try to disable Windows Firewall AND any antivirus software/suite/whatever. If this fail, use Wireshark and try to monitor MDNS traffic. Plan C would be to try to install portable Arduino version and (when asking) allow all network communications in the firewall settings. Plan D then - don't use Windows(I'm out of plans actually...).
schufti wrote:hmm, there are WiFi routers where
a) WiFi can be isolated from LAN, only allowing access to WAN.
b) WiFi stations are isolated from each other
Just for plan E ... check router settings, move PC from LAN to WiFI or vice versa
