err = tcp_close(_pcb);
tcp_abort(_pcb);
if(err != ERR_OK) {
This fixes the "memory leak" and does not seem to harm the Webserver example.
Explore... Chat... Share...
jwatte wrote:Also, if you're planning on turning your project into a real product, hacks like these are how embedded web servers come to be known as sleeping bombs in everyone's house.
Knowing When to Keep Quiet
To be sure that a TCP does not create a segment that carries a
sequence number which may be duplicated by an old segment remaining in
the network, the TCP must keep quiet for a maximum segment lifetime
(MSL) before assigning any sequence numbers upon starting up or
recovering from a crash in which memory of sequence numbers in use was
lost. For this specification the MSL is taken to be 2 minutes.
