I poked around the ESP8266WiFi.h file and noticed I could use softAP(ssid, pass, channel);. I changed the name of the AP, set a password and channel 6. When attempting to connect to this network I am able to connect but my computer insists that I have a self assigned IP address. It continues to try and obtain an IP address but I never end up with 192.168.4.2 or an assigned router for that matter. I'm using OS X 10.9 at the moment but I doubt that makes much difference considering it works both other ways; see below.
When using the command softAP(ssid); I can assign a new network name and everything works fine as in the mode(WIFI_AP); except of course that I’m still on channel 1.
I’m pretty sure this is a bug but considering how green I am with this perhaps I’m missing something.
On an unrelated note; is there a way to digitalRead(PORTX) or the status of individual output pins? I was playing around with the example code and wanted to read the status of a GPIO output pin and return the information to the user in the event they made an invalid request. I don’t want to actually change the pin to an input; just see whether the output status is currently high or low.
