I have included a version to read the name of the device presented to Alexa to be collected from SDCard.
This will allow the configuration without reprogramming the ESP, SSID and PASS from SDCard also.
These have been set to use the cheap RF sockets from Maplin with rotary ID Switches, edit the SwitchRF to set your own codes.
With SDCard....
* ESP9266 WEMO Emulator to Amazon Alexa with Webpage Buttons
* This uses an SDCard attached to SPI to get the Names for the Fauxmo devices
* The SSID and Password are also stored on the SDCard in the files...
* SSID.TXT = Network Name (SSID)
* WIFIPSK.TXT = Network Password
* DEVICES.TXT = FauMo/Alexa Names List - Each device name terminated with a comma e.g. Beacon One,Beacon Two,
* Make the name 5 chars or greater, HTML will increase the size of the buttons on the webpage to asccomodate
* SPI PINS
* | GPIO NodeMCU Name |
* | 15 D8 SS |
* | 13 D7 MOSI |
* | 12 D6 MISO |
* | 14 D5 SCK |
#include <SPI.h>
#include <SD.h>
#include "fauxmoESP.h"
#include <RCSwitch.h>
// RCSwitch configuration
RCSwitch mySwitch = RCSwitch(); // 433MHz Transmitter on Pin 4
// Create an instance of the server on Port 80 for webpage
WiFiServer server(80);
WiFiClient client;
unsigned long ulReqcount; // how often has a valid page/button been requested
// List of default Alexa Device Names to be replaced by SDCard names if found
String AlexaName[] = {"Light one","Light two","Light three","Light four","Light five","Light six"};
// Network configuration
fauxmoESP fauxmo;
char ssid[32]; // Storage for your network SSID (name) from SDCard
char pass[32]; // Strorage for your network password from SDCard
// Allow access to ESP8266 SDK calls
extern "C"
#include "user_interface.h"
// Switch the RF433 Sockets on/off Set this for your type of Sockets these have Rotory Switches to set ID
void SwItchRF( unsigned char deviceid, boolean Mystate, const char * devicename ){
Serial.printf("[MAIN] Device #%d (%s) state: %s\n", deviceid, devicename, Mystate ? "ON" : "OFF");
if(deviceid == 0){
if(Mystate==true){
mySwitch.switchOn(1,1);
}else{
mySwitch.switchOff(1,1);
}else if(deviceid==1){
if(Mystate==true){
mySwitch.switchOn(1,2);
}else{
mySwitch.switchOff(1,2);
}else if(deviceid==2){
if(Mystate==true){
mySwitch.switchOn(1,3);
}else{
mySwitch.switchOff(1,3);
}else if(deviceid == 3){
if(Mystate==true){
mySwitch.switchOn(1,4);
}else{
mySwitch.switchOff(1,4);
}else if(deviceid==4){
if(Mystate==true){
mySwitch.switchOn(2,1);
}else{
mySwitch.switchOff(2,1);
}else if(deviceid == 5){
if(Mystate==true){
mySwitch.switchOn(2,2);
}else{
mySwitch.switchOff(2,2);
}else{return;}
Serial.printf("Initializing SD card...");
if (!SD.begin(15)) {
Serial.printf("Card Not Present!\r\n");
//return;
}else{
Serial.printf("initialization done.\r\n");
File myFile = SD.open("devices.txt");
if (myFile) {
Serial.printf("devices.txt:\r\n");
int SinGle = 0;
// read from the file until there's nothing else in it:
while (myFile.available()) {
String ReadDevice = myFile.readStringUntil(','); // Terminate each device name with a comma
ReadDevice.trim();
int LengtH = ReadDevice.length();
if (LengtH>=5){
AlexaName[SinGle] = ReadDevice;
Serial.println(ReadDevice);
SinGle++;
ReadDevice = "";
// close the file:
myFile.close();
} else {
// if the file didn't open, print an error:
Serial.println("error opening devices.txt");
File myFile0 = SD.open("ssid.txt");
if (myFile0) {
String tmsg="";
Serial.println("ssid.txt:");
while (myFile0.available()) {
tmsg=myFile0.readString();
tmsg.trim();
int len = tmsg.length()+1;
ssid[len];
tmsg.toCharArray(ssid, len);
// close the file:
myFile0.close();
Serial.println(ssid);
} else {
Serial.println("error opening ssid.txt");
File myFile1 = SD.open("wifipsk.txt");
if (myFile1) {
String tmsg1="";
Serial.println("wifipsk.txt:");
while (myFile1.available()) {
tmsg1=myFile1.readString();
tmsg1.trim();
int len1 = tmsg1.length()+1;
pass[len1];
tmsg1.toCharArray(pass, len1);
// close the file:
myFile1.close();
Serial.println(pass);
} else {
Serial.println("error opening wifipsk.txt");
Serial.print(F("\r\n\r\nConnecting to "));
Serial.println(WiFi.SSID().c_str());
WiFi.begin(ssid, pass);
Serial.print(F("."));
Serial.printf("\r\n\r\n[WIFI] STATION Mode, SSID: %s, IP address: %s\n", WiFi.SSID().c_str(), WiFi.localIP().toString().c_str());
server.begin();
mySwitch.enableTransmit( 4 ); // 433MHz Transmitter
// Fauxmo
fauxmo.addDevice(AlexaName[0].c_str());
fauxmo.addDevice(AlexaName[1].c_str());
fauxmo.addDevice(AlexaName[2].c_str());
fauxmo.addDevice(AlexaName[3].c_str());
fauxmo.addDevice(AlexaName[4].c_str());
fauxmo.addDevice(AlexaName[5].c_str());
// fauxmoESP 2.0.0 has changed the callback signature to add the device_id
// it's easier to match devices to action without having to compare strings.
fauxmo.onMessage([](unsigned char device_id, const char * device_name, bool state) {
SwItchRF( device_id, state, device_name );
// Since fauxmoESP 2.0 the library uses the "compatibility" mode by
// default, this means that it uses WiFiUdp class instead of AsyncUDP.
// The later requires the Arduino Core for ESP8266 staging version
// whilst the former works fine with current stable 2.3.0 version.
// But, since it's not "async" anymore we have to manually poll for UDP
// packets
fauxmo.handle();
if (!client)
return;
// Wait until the client sends some data
unsigned long ultimeout = millis()+250;
while(!client.available() && (millis()<ultimeout) )
delay(1);
if(millis()>ultimeout)
return;
String sRequest = client.readStringUntil('\r');
client.flush();
// stop client, if request is empty
if(sRequest=="")
client.stop();
return;
// get path; end of path is either space or ?
// Syntax is e.g. GET /?show=1234 HTTP/1.1
String sPath="",sParam="", sCmd="";
String sGetstart="GET ";
int iStart,iEndSpace,iEndQuest;
iStart = sRequest.indexOf(sGetstart);
if (iStart>=0)
iStart+=+sGetstart.length();
iEndSpace = sRequest.indexOf(" ",iStart);
iEndQuest = sRequest.indexOf("?",iStart);
// are there parameters?
if(iEndSpace>0)
if(iEndQuest>0)
// there are parameters
sPath = sRequest.substring(iStart,iEndQuest);
sParam = sRequest.substring(iEndQuest,iEndSpace);
else
// NO parameters
sPath = sRequest.substring(iStart,iEndSpace);
// format the html response
if(sPath=="/")
ulReqcount++;
String diagdat="";
String duration1 = " ";
int hr,mn,st;
st = millis() / 1000;
mn = st / 60;
hr = st / 3600;
st = st - mn * 60;
mn = mn - hr * 60;
if (hr<10) {duration1 += ("0");}
duration1 += (hr);
duration1 += (":");
if (mn<10) {duration1 += ("0");}
duration1 += (mn);
duration1 += (":");
if (st<10) {duration1 += ("0");}
duration1 += (st);
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
client.println("<!DOCTYPE HTML>");
diagdat+="<html><head><title>Home Monitor</title></head><body>";
diagdat+="<font color=\"#000000\"><body bgcolor=\"#a0dFfe\">";
diagdat+="<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\">";
diagdat+="<h1>Alexa Home Control<BR>ESP8266 FauxMo Device Control</h1>";
diagdat+="<BR> Web Page Requests = ";
diagdat+=ulReqcount;
diagdat+="<BR> Free RAM = ";
client.println(diagdat);
client.print((uint32_t)system_get_free_heap_size()/1024);
diagdat=" KBytes";
diagdat+="<BR> System Uptime =";
diagdat+=duration1;
client.print(diagdat);
diagdat="<BR><hr><BR><table><tr><td>";// Webpage buttons for RF 433 Sockets in HTML Table
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=1-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[0].c_str();
diagdat+=" On\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=2-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[1].c_str();
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=3-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[2].c_str();
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=4-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[3].c_str();
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=5-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[4].c_str();
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=6-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[5].c_str();
diagdat+=" On\"></FORM><br></td></tr><tr><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=1-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=" Off\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=2-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=3-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=4-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=5-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=6-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=" Off\"></FORM><br></td></tr></table>";
diagdat="<hr><BR>";
diagdat+="<BR><FONT SIZE=-1>environmental.monitor.log@gmail.com<BR><FONT SIZE=-1>ESP8266 With RF 433MHz Sockets <BR> FauxMO (WEMO Clone) to Amazon ECHO Dot Gateway<BR>";
diagdat+="<FONT SIZE=-2>Compiled Using ESP ver. 2.2.3(Arduino 1.6.13), built March, 2017<BR></body></html>";
diagdat = "";
duration1 = "";
// and stop the client
delay(1);
client.stop();
// React to Button Click from Webpage
if (sPath.startsWith("/&socKet=")){ // Request from webpage buttons
client.println("HTTP/1.1 204 OK"); // No Data response to buttons request
client.println("Connection: close"); // We are done Close the connection
delay(1); // Give time for connection to close
client.stop(); // Stop the client
ulReqcount++; // Tracking counter for page requests
boolean state;
unsigned char device_id;
const char * devicename = "Webpage";
if (sPath.startsWith("/&socKet=1-on")) {
device_id=0;
state=true;
SwItchRF( device_id, state, devicename );
} else if (sPath.startsWith("/&socKet=1-off")) {
device_id=0;
state=false;
} else if (sPath.startsWith("/&socKet=2-on")) {
device_id=1;
state=true;
} else if (sPath.startsWith("/&socKet=2-off")) {
device_id=1;
state=false;
} else if (sPath.startsWith("/&socKet=3-on")) {
device_id=2;
state=true;
} else if (sPath.startsWith("/&socKet=3-off")) {
device_id=2;
state=false;
} else if (sPath.startsWith("/&socKet=4-on")) {
device_id=3;
state=true;
SwItchRF( device_id, state, devicename);
} else if (sPath.startsWith("/&socKet=4-off")) {
device_id=3;
state=false;
} else if (sPath.startsWith("/&socKet=5-on")) {
device_id=4;
state=true;
} else if (sPath.startsWith("/&socKet=5-off")) {
device_id=4;
state=false;
} else if (sPath.startsWith("/&socKet=6-on")) {
device_id=5;
state=true;
} else if (sPath.startsWith("/&socKet=6-off")) {
device_id=5;
state=false;
}else{return;}
Without SDCard, this uses 433MHz + 315MHz
RCSwitch s3Switch = RCSwitch(); // 315MHz Transmitter
WiFiClient client;
unsigned long ulReqcount; // how often has a valid page been requested
fauxmoESP fauxmo;
#define WIFI_SSID "YourSSID"
#define WIFI_PASS "YOURPassword"
// Declared for the webpage
extern "C"
// Switch the RF433/315 Sockets on/off
void SwItchRF( unsigned char deviceid, boolean Mystate ){
if(deviceid == 0){ // Livingroom Lamp (433MHz)
if(Mystate==true){
}else{
}else if(deviceid==1){ // Hall White LED's (433MHz)
if(Mystate==true){
}else{
}else if(deviceid==2){ // Kitchen LED's (433MHz)
if(Mystate==true){
}else{
}else if(deviceid == 3){ // Bedroom Lamp (433MHz)
if(Mystate==true){
}else{
}else if(deviceid==4){ // Hall Ceiling Light (315MHz)
if(Mystate==true){
s3Switch.send(2839714, 24);
}else{
s3Switch.send(2839721, 24);
}else if(deviceid == 5){ // Livingroom Ceiling Light (315MHz)
if(Mystate==true){
s3Switch.send(2391202, 24);
}else{
s3Switch.send(2391209, 24);
}else{return;}
WiFi.begin(WIFI_SSID, WIFI_PASS);
delay(100);
server.begin();
s3Switch.enableTransmit( 5 ); // 315MHz Transmitter
// Fauxmo
fauxmo.addDevice("lamp");
fauxmo.addDevice("hall");
fauxmo.addDevice("kitchen");
fauxmo.addDevice("bedroom");
fauxmo.addDevice("main hall");
fauxmo.addDevice("livingroom");
Serial.printf("[MAIN] Device #%d (%s) state: %s\n", device_id, device_name, state ? "ON" : "OFF");
SwItchRF( device_id, state );
// packets
fauxmo.handle();
if (!client)
return;
delay(1);
return;
client.flush();
if(sRequest=="")
client.stop();
return;
if (iStart>=0)
if(iEndSpace>0)
if(iEndQuest>0)
else
// NO parameters
if(sPath=="/")
ulReqcount++;
String diagdat="";
int hr,mn,st;
mn = st / 60;
hr = st / 3600;
st = st - mn * 60;
mn = mn - hr * 60;
duration1 += (hr);
duration1 += (":");
duration1 += (mn);
duration1 += (":");
duration1 += (st);
client.println();
diagdat+="<h1>Alexa Home Voice / Webpage Control<BR>ESP8266 FauxMo Device</h1>";
diagdat=" KBytes";
diagdat+=duration1;
diagdat="<BR><hr><BR><table><tr><td>";// Webpage buttons for RF 433/315 in HTML Table
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=1-on\"><INPUT TYPE=\"submit\" VALUE=\"Lamp On\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=2-on\"><INPUT TYPE=\"submit\" VALUE=\"Hall LED On\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=3-on\"><INPUT TYPE=\"submit\" VALUE=\"Kitchen On\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=4-on\"><INPUT TYPE=\"submit\" VALUE=\"Bedroom On\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=5-on\"><INPUT TYPE=\"submit\" VALUE=\"Hall Main On\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=6-on\"><INPUT TYPE=\"submit\" VALUE=\"Livingroom On\"></FORM><br></td></tr><tr><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=1-off\"><INPUT TYPE=\"submit\" VALUE=\"Lamp Off\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=2-off\"><INPUT TYPE=\"submit\" VALUE=\"Hall LED Off\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=3-off\"><INPUT TYPE=\"submit\" VALUE=\"Kitchen Off\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=4-off\"><INPUT TYPE=\"submit\" VALUE=\"Bedroom Off\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=5-off\"><INPUT TYPE=\"submit\" VALUE=\"Hall Main Off\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=6-off\"><INPUT TYPE=\"submit\" VALUE=\"Livingroom Off\"></FORM><br></td></tr></table>";
diagdat="<hr><BR>";
diagdat+="<BR><FONT SIZE=-1>environmental.monitor.log@gmail.com<BR><FONT SIZE=-1>ESP8266 With RF 433MHz + 315MHz <BR> FauxMO(WEMO Clone) to Amazon ECHO Dot Gateway<BR>";
diagdat = "";
duration1 = "";
delay(1);
client.stop();
boolean state;
device_id=0;
state=true;
SwItchRF( device_id, state ); // Button request to SwItchRF()
device_id=0;
state=false;
device_id=1;
state=true;
device_id=1;
state=false;
device_id=2;
state=true;
device_id=2;
state=false;
device_id=3;
state=true;
device_id=3;
state=false;
device_id=4;
state=true;
device_id=4;
state=false;
device_id=5;
state=true;
device_id=5;
state=false;
}else{return;}
