I have been googling for few days now and can't just figure this out.
My goal is to buildt few ESP-12-F modules with different kinds of sensors and make them to send data in JSON. So step by step:
1. Go it ESP IP address with browser, lets say 192.168.2.25/
2. ESP would respond with JSON, like: {"humidity": "55","temperature": "22"}
This works with a google chrome but I can't get it working with javascript. I have been using Philips HUE API debug tool so it should be covered.
If I point the debug tool to the ESP IP address 192.168.2.25/ I get Error 404. But for comparison if I put this to the debugger "http://echo.jsontest.com/humidity/55/temperature/22" I get correct JSON response back.
Philips code below:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>API Debug tool</title>
<style>
body{
font-family: verdana;
margin: 20px;
h1{
margin: 0px;
font-size: 20px;
h2{
font-size: 16px;
margin-top: 20px;
color: grey;
#buttons{
clear: left;
input{
width: 100%;
form{
background: #e8e8e8;
width: 500px;
padding: 20px;
-webkit-border-radius: 10px;
-moz-border-radius: 10px;
textarea{
padding-top: 10px;
width: 100%;
font-family: monaco,monospace;
font-size: 12px;
</style>
</head>
<body>
<form name="commandform">
<h1>CLIP API Debugger</h1>
<h2>URL:</h2>
<input name="commandurl" type="text" size="60" value="/api/1234/">
<div id="buttons">
<button type="button" onclick="getHTML('GET')">GET</button>
<button type="button" onclick="getHTML('PUT')">PUT</button>
<button type="button" onclick="getHTML('POST')">POST</button>
<button type="button" onclick="getHTML('DELETE')">DELETE</button>
</div>
<h2>Message Body:</h2>
<textarea name="messagebody" rows="10" cols="100"></textarea>
<h2>Command Response:</h2>
<textarea name="response" rows="25" cols="100"></textarea>
</form>
</body>
</html>
<script language="JavaScript">
function getHTML(command)
if (window.XMLHttpRequest)
var http = new XMLHttpRequest();
http.open(command, document.commandform.commandurl.value, true);
http.onreadystatechange = function()
if(http.readyState == 4)
if(http.status==200)
document.commandform.response.value="Bad JSON: "+http.responseText
document.commandform.response.value=JSON.stringify(JSON.parse(http.responseText), null, '\t');
else
document.commandform.response.value="Error "+http.status
http.send(document.commandform.messagebody.value);
return false;
</script>
I tried this: viewtopic.php?f=29&t=7158
And it "works" but I have the same problem as the last two replies. My ESP posts the JSON back quite slowly and Philips HUE debugger doesn't receive it. I tried many other codes too, but I'm having huge troubles finding examples on how to repond to GET with JSON. There are many examples how to POST or GET JSON with ESP but in my case the GET is coming from somewhere else and the ESP should response with JSON.
I ran out of ideas what to do. Can someone point me to right direction or check what is my mistake? My ESP code below. Mostly copied from WifiWebServer example.
#include <ArduinoJson.h>
#include <SimpleDHT.h>
const char* ssid = "xxx";
const char* password = "xxx";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
int pinDHT11 = 16;
SimpleDHT11 dht11;
byte temperature = 0;
byte humidity = 0;
unsigned long timeForDHT=millis();
delay(10);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
// Start the server
server.begin();
// Print the IP address
//Read temperatyre and humidity every one second
if(millis() > timeForDHT + 1000)
if (dht11.read(pinDHT11, &temperature, &humidity, NULL))
Serial.print("Read DHT11 failed.");
//Serial.print((int)temperature); Serial.print(" *C, ");
//Serial.print((int)humidity); Serial.println(" %");
timeForDHT = millis();
if (!client) {
return;
// Wait until the client sends some data
Serial.println("new client");
while(!client.available()){
delay(1);
Serial.println(req);
client.flush();
// Match the request
if (req.indexOf("/") != -1)
else {
Serial.println("invalid request");
client.stop();
return;
client.flush();
// Prepare the response
String s = "HTTP/1.1 200 OK\r\nContent-Type: application/json\r\n\r\n{\"IDkey\":\"ESP-1\",\"sensors\":{\"1\":{\"type\":\"humidity\",\"value\":0},\"2\":{\"type\":\"temperature\",\"value\":0},}}\r\n\r\n";
// Send the response to the client
client.print(s);
delay(1);
Serial.println("Client disonnected");
// The client will actually be disconnected
// when the function returns and 'client' object is detroyed
