- Fri Jan 17, 2020 8:54 pm
#85304
I spent a lot of time on this and found a solution. First was that it only worked with some pins. I found it wouldn't work with D0, D3 or D4 but it would work with D5 and D6. Second problem was that nice wrapper Dallas module didn't work but the OneWire library worked fine. I made some changes to the sample code so that it loops through multiple sensors on the same pin in the one call. I also changed it to remove the 1000ms delay. Normally you need to request the sensor to take a reading, wait 1000ms and then read the data. I changed it so that it reads the data and then requests the sensor to take a reading. This means the reading will be there for the next time you call it. This means that you are good as long as you don't request a temperature more than once per second. The downside to that is that the reading is going be outdated if you don't take readings very often.
Code: Select all#include <OneWire.h>
OneWire ds(D5); // on pin D5 (a 4.7K resistor is necessary)
void setup()
Serial.begin(9600);
delay(1000);
readTemps();
void readTemps()
ds.reset_search();
byte addr[8];
while(ds.search(addr))
if (OneWire::crc8(addr, 7) != addr[7])
Serial.println("CRC is not valid!");
break;
// the first ROM byte indicates which chip
byte type_s;
switch (addr[0])
case 0x10://DS18S20
type_s = 1;
break;
case 0x28://DS18B20
type_s = 0;
break;
case 0x22://DS1822
type_s = 0;
break;
default:
Serial.println("Device is not a DS18x20 family device.");
break;
ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
byte data[12];
for (byte i = 0; i < 9; i++)
data[i] = ds.read();
// Convert the data to actual temperature
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
raw = (raw & 0xFFF0) + 12 - data[6];
else
byte cfg = (data[4] & 0x60);
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
float celsius = (float)raw / 16.0;
Serial.print(celsius);
Serial.print("C ");
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // Read temp
