Even with the lower regulated current from 2 relays it is still not a great idea to pass that current through the NodeMCU regulator. Even if it can supply the current it will lead to significantly more heat being dissipated by that regulator.
As suggested maybe get the development working with 1 or 2 relays then think through your power supply arrangements when deploying a real solution.
