By kolban
#31373 Looking at the document from Espressif called "ESP8266 AT Instruction Set v0.40" I don't see any commands related to Simple Network Time Protocol (SNTP) which is what is used to retrieve the current time. The SNTP APIs are available for SDK applications written in C but I don't believe these have been mapped to the AT command processor.
By torntrousers
#31405 The HTTP RFC defines a Date header so pretty much all websites will return the current date/time in all http responses, so you can use that. Here's a sketch function to do that by making an HTTP HEAD request to google.com:
Code: Select allString getTime() {
  WiFiClient client;
  while (!!!client.connect("google.com", 80)) {
    Serial.println("connection failed, retrying...");
  client.print("HEAD / HTTP/1.1\r\n\r\n");
  while(!!!client.available()) {
     yield();
  while(client.available()){
    if (client.read() == '\n') {
      if (client.read() == 'D') {
        if (client.read() == 'a') {
          if (client.read() == 't') {
            if (client.read() == 'e') {
              if (client.read() == ':') {
                client.read();
                String theDate = client.readStringUntil('\r');
                client.stop();
                return theDate;
That will return a String like "Thu, 15 Oct 2015 08:57:03 GMT"
