i have a project of arduino uno and esp-12
arduino is reading some sensors data and sen it serially to esp
i need the code of esp to read the serial data ^^
Explore... Chat... Share...
maxmaxy21 wrote:Help Needed!!
danbicks wrote:maxmaxy21 wrote:Help Needed!!
Why don't you consider turning the Uno in to an I2C slave device, the ESP could then simply use the wire library to access the uno and request data respectively. Their are lots of tutorials on Uno as an I2C slave.
Dans
