Regards!!!!
Regards!!!!
Explore... Chat... Share...
Albertooo wrote:I have located a little more the fault. If I turn on the heat pump (heat mode) with the remote (par21maa) and command by mqtt {"mode": "HEAT"} the pump should ignore this order because it is already in heat mode and should not do anything, That order the pump goes off. If I turn on mqtt the pump and put it on mqtt {"mode": "HEAT"} if it does the right thing and ignores the order.
Regards!!!!
