By mrburnette
#50296 @markingle :
An excellent example; however the cut&paste from this webpage created some issues due to junk being picked-up in the copy. So, after I got it all corrected and compiled, I did a little aesthetic engineering :lol: and added come comments. I also (for those not familiar with Steinhart-Hart) simplified that function so newbies could follow (note: replace with @markingle's original for better accuracy.) At 25C a Vishay 10K NTC is spot-on and in an ice bath, it is maybe 1C difference with my NIST traceable thermometer... good 'nuff for a demo, IMO.
I have created a Zip of the Arduino 1.6.9 multi-tab project. I compiled and tested under Linux but Windows IDE users should have no issues although I cannot test.
Regards,
Ray
NTC == Vishay 10K NTC
Series resistor 150K
If using a NodeMCU with a resistor divider, you must remove both SMT resistors. Then the hookup is very simple:
Code: Select all3.3V --------------/\/\/\/\/\/\/-----------+--------------NTC--------------Gnd
                      150K 1%                           10K Vishay
Just connect the actual A0 pin to the "+" junction and that is that! The voltages will range for 0C to 100C within the ESP8266 0V to 1V ADC range. Below is what happened when I threw the sensor into an ice-bath and then into my coffee ... Ouch :shock:
ImageScreenshot from 2016-07-06 09:46:36 by Rayburne, on Flickr[/img]
And wirelessly on an old HP-mini:
Image20160617_123450 by Rayburne, on Flickr[/img]
By mrburnette
#59893
hoacvxd wrote:To mrburnette:
I've downloaded your project about but do not know how to add libraries to the mycomputer to compile. Please help me.
Sincerely thank you.
Regrets regarding the delay in getting back to you ...
I really cannot easily answer this because you do not specify the specific lib(s); but generally the process is to download a Zip from the Internet, then use the Arduino IDE load library from Zip.
Now, in the project article, I did mark the project as "advanced."
Good luck,
Ray
