rudy wrote:The Espressif bootloader starts up and if the control inputs are set to run code (instead of load code to flash) it then will run the program. That will be whatever program was last loaded. Every time you load a new program it overwrites what was previously there. So even running something small like the blink program, it will destroy whatever program was there before. And the program that used AT commands as input, it is history on the first sketch you uploaded. Of course you could reload that code. But whenever you program new code it overwrites the previous code.
You can enable verbose diagnostic output. I have it on the version I run at home but I can't recall exactly what it is called. It is under the tools menu. Near the board selection.
I've made some progress which has given me some comfort that is not a hardware issue.
- flashed using NONOS_SDK_V2.0.0.0_16_07_19
Ran putty and using AT+CWMODE=3 followed by AT+CWLAP I recieved full list of AP detected by my ESP8266
Before disconnecting I ran
AT+CWMODE_DEF=3
Reconnected my usb, started Arduinio IDE and loaded the Wifiscan sketch, Then Bingo an AP list was displayed in the serial monitor. As 2nd test, I reset the ESP8266 and uploaded another sketch, this time the wifiacesspoint sketch. Saw the AP listed on my Iphone and was able to connect to the webserver.
I'm happy this is working, but i'm not clear on the fix. While it looks like running the command AT+CWMODE_DEF=3 solved my problem but I expect this setting was overwritten when I uploaded the first sketch.
Or was it just that I flashed esp8266 before uploading the ardunio sketch and this needs to be done *sometimes* (or everytime)prior to uploading a new sketch to avoid issue?
