Albertooo wrote:Hi swicago,
Can you help me?
My european unit pead rp100 ja dont work with this tructure header bytes.
i have wifi adaptor mac-55-ife7 and works well
How could I figure out the byte structure of my heat pump?
I made your schema with wittycloud esp8266 and my heat pump does nothing.
Thanks in advance
Albertooo wrote:with hadley code python and raspberry connected with heat pump with usb to ttl, i can see the header and the protocol?
Thanks in advance!!!!
Regadrs
Make sure you have the pull up resistors on TX and RX. It did not work for me either, until I did this.
BTW, Hadley's is in NZ and I am in US, both of our units work based off his original python. SO I would be very surprised if EU had a different protocol, especially if the connector is cn105 as well.
You can also use a RaspPi and Hadley's python just to see it work with his code. It may also need pull ups on TX and RX.
