By zammykoo
#56130 This worked great. Thanks!
oeyhaga wrote:Seem I'v solved the problem. As easy as adding a longer delay after GET command.
Changed delay(10); to delay(500)
Finaly I can continue with the project after many hours scratching my head :P
const char* ssid     = "NAME";
const char* password = "PASSWORD";
const char* host = "api.thingspeak.com";
int value = 1;
  delay(10);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
}//end setup
  delay(5000);
  Serial.println(host);
  WiFiClient Client;
  const int httpPort = 80;
  if (!Client.connect(host, httpPort)) {
    Serial.println("Connection failed");
    return;
  // We now create a URI for the request
  String url = "/apps/thinghttp/send_request?api_key=PAW43HX9QN9SVOW1";
  Serial.println(host + url);
  Serial.println(String("TRY: ") + value + ".");
 Client.print(String("GET ") + url + "&headers=false" + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" + "Connection: close\r\n\r\n");
  while(Client.available()){
  String line = Client.readStringUntil('\r');
  Serial.println(line);
  Serial.println("");
  Serial.println(String("Try nr. ") + value + " is finished.");
  Serial.println("Waiting for next try...");
  Serial.println("");
  value = value + 1;
  delay(20000);
By shawnleo
#56217 Hi,
I used your code and it works great. Thanks for sharing! However, before using your code, I was trying to use the following http request:
https://thingspeak.com/channels/channel/fields/1/last
This needs HTTPS connection but it skipped the ThingHTTP app step.
I tried many many times but did not get it working. Sorry I am just a noob and could you please let me know how to do it?
Thanks a lot! :D
