By LeXLuther422
#18533 Here is kind of the start and basic layout i'm going to use. Going for a single sided board.
Here is after a smoke break and some thought...
By GeorgeIoak
#18543 You might also think about adding a pull-up resistor for the enable pin rather than directly connecting it to Vcc. This would allow you to externally disable the module if you ever wanted. This has a very similar, if not identical, function as reset and the module you are using doesn't expose the reset pin.
