David
David
Explore... Chat... Share...
wickwirew wrote:You are right about the dependencies. I got it work work by editing the library and adding my own pow()and sqrt() method. Ill attach the edited library. So just go into your documents and delete the old one then add mine and it should work! Let me know if you have any issues.
