By EREN MERT
#57536 Hello
great example and I also started reading your blog thank you.
I want to try this but i got an error. I tried with v1.9 and last version of pubsubclient. Do I need other libraries?
In file included from C:\xxx\Desktop\MqttTimer\MqttTimer.ino:39:0:
sketch\globals.h: In function 'void ConnectMQTT()':
globals.h:195: error: 'MQTT' has not been declared
while (!client.connect(MQTT::Connect(config.clientID).set_auth(config.MQTTuser, config.MQTTpass)) && retries--)
In file included from C:\xxx\Desktop\MqttTimer\MqttTimer.ino:40:0:
sketch\MQTTHandler.h: At global scope:
MQTTHandler.h:7: error: 'MQTT' does not name a type
void callback(const MQTT::Publish& pub)
MQTTHandler.h:7: error: expected unqualified-id before '&' token
MQTTHandler.h:7: error: expected ')' before '&' token
MQTTHandler.h:7: error: expected initializer before 'pub'
exit status 1
By Godfather
#57571 Hi not sure why you're getting errors like that?
Pubsubclient should be v1.9 also make sure you don't change the order of the include libraries in the main
sketch.
By ChenBH
#57584 That was the next stage in my home automation project!
I needed the knowledge and implementation of MQTT and NTP to make some timer-controled devices.
Thanks man.
