- Sun Sep 27, 2015 6:58 am
#29972
I'm using MQTT_led_v1.06 arduino 1.6.5 the MQTT_led_v1.06 is unmodified
Tools board manager esp8266 version is 1.6.5-947-g39819f0 I was using arduino 1.6.2 and just the generic esp82666 board.
Mostly if it isn't broken I don't upgrade since all to often it leads to little satisfaction since the gain is small and the risk to the stability of an existing system is high. In this case things are broken and I have a back up so I can return to 1.6.2 if needed.
I have upgraded to 1/6/5 and learned a lot form this ...mostly that there are massive dependencies with the Arduino IDE
kas thanks for your help with this but the errors are still there
I have learned a lot form this ...mostly that there are massive dependencies with the Arduino IDE between versions boards etc.
Issue
The error appears to be with the MQTT code since it persists in different versions of the Arduino IDE
The MQTT.cpp has no internal versioning information in the code file so could have out of date code
Here is what is in the code file
MQTT.cpp - MQTT packet classes
Copyright (C) 2015 Ian Tester
Compile errors
[code]In file included from MQTT.cpp:20:0:
MQTT.h:278: error: '__FlashStringHelper' does not name a type
Publish(String topic, const __FlashStringHelper* payload);
MQTT.h:278: error: ISO C++ forbids declaration of 'payload' with no type [-fpermissive]
MQTT.h:280: error: 'PGM_P' has not been declared
friend Publish Publish_P(String topic, PGM_P payload, uint32_t length);
MQTT.h:321: error: 'PGM_P' has not been declared
MQTT.cpp:358: error: '__FlashStringHelper' does not name a type
Publish::Publish(String topic, const __FlashStringHelper* payload) :
MQTT.cpp:358: error: ISO C++ forbids declaration of 'payload' with no type [-fpermissive]
[/code]
Later today I'll retest my esp8266 code that compiled under 1.6.2 to see if it still works....hopefully it will.
