Is it possible to send this data to a Windows 7 PC wirelessly for display purposes? If so, how would I start?
I'm a newbie to this so please explain any suggestions in detail
Explore... Chat... Share...
// Processing UDP example to send and receive binary data
// https://thearduinoandme.wordpress.com/t utorials/esp8266-send-receive-binary-data/
// Badly hacked by Ray B. to display the UDP broadcast from ESP8266
import hypermedia.net.*; // http://ubaa.net/shared/processing/udp/udp_class_udp.htm
String ip = "10.10.10.1"; // the remote IP address of ESP8266
int port = 8888; // the destination port - any unused port
long previousMillis = 0;
long interval = 500;
UDP udp;
udp = new UDP(this, 8888);
udp.listen( true );
void draw() {
if (previousMillis < millis() - interval) {
previousMillis = previousMillis + interval;
byte[] message = new byte[2];
message[0] = 0; message[1] = 0;
udp.send(message, ip, port);
void keyPressed() {
if (key == '-')
void keyReleased() {
if (key != '-') {
void receive( byte[] data ) { // <– default handler
for (int i=0; i < data.length; i++)//void receive( byte[] data, String ip, int port ) { // <– extended handler
print(char(data[i]));
println();
}It takes about 20-25 seconds for home assistant c[…]
