By polypagan
#58916 I don't know if this is even useful. I wrote it to diagnose/confirm troubles with an Amica NodeMCU module that only reports <ROM gobbledygook>MEMORY FAULT.
It didn't find the problem (which leaves me still in the dark), but I believe it would if the tested RAM where faulty.
Anyhow, here it is. Not polished. Let me know what you think if you play with it.
Code: Select all/*************************************************************************
 * 20161129 DdelV
 * Can ESP8266/ATmega328p RAM be tested?
 * Apparently so, if one is careful!
 * This code was written (and cribbed) to test ESP8266 RAM
 * Also works on Arduino chips, if there's a UART.
 * Allocate (just about) the largest chunk of
 * RAM that malloc() can be made to return, and tests that
 * (or most of it).
 * Works! (occasionally stack dumps on ESP8266)
int stackBot()
  int v;  // declare a dynamic variable
  return (int) &v;  // return it's address, that's stack bottom (right now..)
 * The following (3) routines are from:
 * http://www.barrgroup.com/Embedded-Systems/How-To/Memory-Test-Suite-C
typedef unsigned char datum;    /* Set the data bus width to 8 bits.  */
 * Function:    memTestDataBus()
 * Description: Test the data bus wiring in a memory region by
 *              performing a walking 1's test at a fixed address
 *              within that region.  The address (and hence the
 *              memory region) is selected by the caller.
 * Notes:
 * Returns:     0 if the test succeeds.
 *              A non-zero result is the first pattern that failed.
datum
memTestDataBus(volatile datum * address)
    datum pattern;
     * Perform a walking 1's test at the given address.
    for (pattern = 1; pattern != 0; pattern <<= 1)
         * Write the test pattern.
        *address = pattern;
         * Read it back (immediately is okay for this test).
        if (*address != pattern)
            return (pattern);
    return (0);
}   /* memTestDataBus() */
 * Function:    memTestAddressBus()
 * Description: Test the address bus wiring in a memory region by
 *              performing a walking 1's test on the relevant bits
 *              of the address and checking for aliasing. This test
 *              will find single-bit address failures such as stuck
 *              -high, stuck-low, and shorted pins.  The base address
 *              and size of the region are selected by the caller.
 * Notes:       For best results, the selected base address should
 *              have enough LSB 0's to guarantee single address bit
 *              changes.  For example, to test a 64-Kbyte region,
 *              select a base address on a 64-Kbyte boundary.  Also,
 *              select the region size as a power-of-two--if at all
 *              possible.
 * Returns:     NULL if the test succeeds.
 *              A non-zero result is the first address at which an
 *              aliasing problem was uncovered.  By examining the
 *              contents of memory, it may be possible to gather
 *              additional information about the problem.
datum *
memTestAddressBus(volatile datum * baseAddress, unsigned long nBytes)
    unsigned long addressMask = (nBytes/sizeof(datum) - 1);
    unsigned long offset;
    unsigned long testOffset;
    datum pattern     = (datum) 0xAAAAAAAA;
    datum antipattern = (datum) 0x55555555;
     * Write the default pattern at each of the power-of-two offsets.
    for (offset = 1; (offset & addressMask) != 0; offset <<= 1)
        baseAddress[offset] = pattern;
     * Check for address bits stuck high.
    testOffset = 0;
    baseAddress[testOffset] = antipattern;
        if (baseAddress[offset] != pattern)
            return ((datum *) &baseAddress[offset]);
    baseAddress[testOffset] = pattern;
     * Check for address bits stuck low or shorted.
    for (testOffset = 1; (testOffset & addressMask) != 0; testOffset <<= 1)
    if (baseAddress[0] != pattern)
      return ((datum *) &baseAddress[testOffset]);
            if ((baseAddress[offset] != pattern) && (offset != testOffset))
    return (NULL);
}   /* memTestAddressBus() */
 * Function:    memTestDevice()
 * Description: Test the integrity of a physical memory device by
 *              performing an increment/decrement test over the
 *              entire region.  In the process every storage bit
 *              in the device is tested as a zero and a one.  The
 *              base address and the size of the region are
 *              selected by the caller.
 * Notes:
 *              incorrect value was read back.  By examining the
datum *
memTestDevice(volatile datum * baseAddress, unsigned long nBytes)
    unsigned long nWords = nBytes / sizeof(datum);
    datum pattern;
    datum antipattern;
     * Fill memory with a known pattern.
    for (pattern = 1, offset = 0; offset < nWords; pattern++, offset++)
     * Check each location and invert it for the second pass.
        antipattern = ~pattern;
        baseAddress[offset] = antipattern;
     * Check each location for the inverted pattern and zero it.
        if (baseAddress[offset] != antipattern)
    return (NULL);
}   /* memTestDevice() */
// select an impossible RAM size based on processor
// (choosing too large a value confuses malloc() on Atmel chip.)
#if defined (__AVR_ATmega328P__)
  unsigned int fR=2048;      // 100% of physical RAM
#else
  unsigned long fR=81920L;    // default to ESP8266
#endif
void *hT;         // these are global (static) because shared between setup() & loop()
// following constant tuned via trial & error.
const int callStack = 20; // allows called test routines to have an absolutely minimal stackframe.
// fR begins very large
  while ((hT = malloc(fR)) == NULL) {
    fR -= 32;   // gradually get real
  Serial.print(fR,DEC);
  Serial.print(F(" (0x"));
  Serial.print(fR,HEX);
  Serial.println(F(") bytes of RAM free."));
  Serial.print(F("Heap top is 0x"));
  Serial.println((int)hT, HEX);
  Serial.print(F("Stack bottom is 0x"));
  Serial.println(stackBot(), HEX);
  Serial.print(F("Testing 0x"));
  Serial.print(fR-callStack, HEX);    // alloc size less stackframe
  Serial.print(F(" bytes from 0x"));
  Serial.print((int)hT, HEX);         // base of RAM to test
  Serial.print(F(" to 0x"));
  Serial.println(stackBot()-callStack, HEX); // limit of testing
unsigned char i=0;  // global to preserve stack space during testing
  datum* bad;
  datum f;
  if ((f=memTestDataBus((datum *)hT)) != 0) {
    Serial.print(F("memTestDataBus(0x"));
    Serial.print(F(") fails with error 0x"));
    Serial.println(f, HEX);
  } else if ((bad = memTestAddressBus((datum *)hT, (unsigned long)(fR-callStack))) != NULL) {
    Serial.print(F("memTestAddressBus(0x"));
    Serial.print(F(") fails at address 0x"));
    Serial.println((int)bad, HEX);
  } else if ((bad = memTestDevice((datum *)hT, (unsigned long)(fR-callStack))) != NULL) {
    Serial.print(F("memTestDevice(0x"));
  } else {    // print milestones (so we know we didn't eat ourselves alive)
    Serial.print('.');
    ++i;
    if ((i % 128) == 0) Serial.println();
Have fun!
By H3wastooshort
#93878 I have made some small changes to the code.
[list=]
[*]Your typedef for the datum was not working for some reason so i just omitted it.
[*]The builtin LED now blinks every newline.
[*]ESP32 RAM size was added.
[*]The dot and newline dividers can be adjusted bet MCU to try and speed up testing.
[/list]
Otherwise very nice. Thank you.
My Sketch:
   20161129 DdelV
   (or most of it).
int stackBot()
   Notes:
unsigned char memTestDataBus(volatile unsigned char * address)
  unsigned char pattern;
    *address = pattern;
      return (pattern);
  return (0);
                possible.
unsigned char * memTestAddressBus(volatile unsigned char * baseAddress, unsigned long nBytes)
  unsigned long addressMask = (nBytes / sizeof(unsigned char) - 1);
  unsigned char pattern     = (unsigned char) 0xAAAAAAAA;
  unsigned char antipattern = (unsigned char) 0x55555555;
  testOffset = 0;
      return ((unsigned char *) &baseAddress[offset]);
      return ((unsigned char *) &baseAddress[testOffset]);
  return (NULL);
   Notes:
unsigned char * memTestDevice(volatile unsigned char * baseAddress, unsigned long nBytes)
  unsigned long nWords = nBytes / sizeof(unsigned char);
  unsigned char antipattern;
  return (NULL);
unsigned int fR = 2048;    // 100% of physical RAM
#define DOT_DIV 1
#define NL_DIV 128
#elif defined (ESP8266)
unsigned long fR = 81920L;  // ESP8266
#define DOT_DIV 4
#define NL_DIV 512
#elif defined (ESP32)
unsigned long fR = 327680L;  // ESP32
#ifndef LED_BUILTIN //Is not defined by default so....
#define LED_BUILTIN 2
#endif
#define DOT_DIV 4
#define NL_DIV 512
#else
#error Uh sorry I have no idea what MCU this is compiling for... Please add it around line 230 together with its RAM size.
#endif
//uint32_t pass = 0;
static bool led_state = false;
  Serial.begin(1000000);
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.print(fR, DEC);
  Serial.print(fR, HEX);
  Serial.print(fR - callStack, HEX);  // alloc size less stackframe
  Serial.println(stackBot() - callStack, HEX); // limit of testing
unsigned char i = 0; // global to preserve stack space during testing
  unsigned char* bad;
  unsigned char f;
  if ((f = memTestDataBus((unsigned char *)hT)) != 0) {
  } else if ((bad = memTestAddressBus((unsigned char *)hT, (unsigned long)(fR - callStack))) != NULL) {
  } else if ((bad = memTestDevice((unsigned char *)hT, (unsigned long)(fR - callStack))) != NULL) {
    ++i;
    if ((i % DOT_DIV) == 0) {
      Serial.print('.');
    if ((i % NL_DIV) == 0) {
      led_state = !led_state;
      digitalWrite(LED_BUILTIN, led_state);
Diff:
Code: Select all2,15c2,15
<  * 20161129 DdelV
<  * Can ESP8266/ATmega328p RAM be tested?
<  * Apparently so, if one is careful!
<  * This code was written (and cribbed) to test ESP8266 RAM
<  * Also works on Arduino chips, if there's a UART.
<  * Allocate (just about) the largest chunk of
<  * RAM that malloc() can be made to return, and tests that
<  * (or most of it).
<  * Works! (occasionally stack dumps on ESP8266)
>    20161129 DdelV
>    (or most of it).
24,30d23
<  * The following (3) routines are from:
<  * http://www.barrgroup.com/Embedded-Systems/How-To/Memory-Test-Suite-C
< typedef unsigned char datum;    /* Set the data bus width to 8 bits.  */
31a25,28
34,46c31,43
<  * Function:    memTestDataBus()
<  * Description: Test the data bus wiring in a memory region by
<  *              performing a walking 1's test at a fixed address
<  *              within that region.  The address (and hence the
<  *              memory region) is selected by the caller.
<  * Notes:
<  * Returns:     0 if the test succeeds.
<  *              A non-zero result is the first pattern that failed.
>    Notes:
48,49c45
< datum
< memTestDataBus(volatile datum * address)
51c47
<     datum pattern;
53a50,54
55,57c56,63
<      * Perform a walking 1's test at the given address.
<     for (pattern = 1; pattern != 0; pattern <<= 1)
>     *address = pattern;
59,70c65
<          * Write the test pattern.
<         *address = pattern;
<          * Read it back (immediately is okay for this test).
<         if (*address != pattern)
<             return (pattern);
>       return (pattern);
71a67
73c69
<     return (0);
>   return (0);
77,99c73,95
<  * Function:    memTestAddressBus()
<  * Description: Test the address bus wiring in a memory region by
<  *              performing a walking 1's test on the relevant bits
<  *              of the address and checking for aliasing. This test
<  *              will find single-bit address failures such as stuck
<  *              -high, stuck-low, and shorted pins.  The base address
<  *              and size of the region are selected by the caller.
<  * Notes:       For best results, the selected base address should
<  *              have enough LSB 0's to guarantee single address bit
<  *              changes.  For example, to test a 64-Kbyte region,
<  *              select a base address on a 64-Kbyte boundary.  Also,
<  *              select the region size as a power-of-two--if at all
<  *              possible.
<  * Returns:     NULL if the test succeeds.
<  *              A non-zero result is the first address at which an
<  *              aliasing problem was uncovered.  By examining the
<  *              contents of memory, it may be possible to gather
<  *              additional information about the problem.
>                 possible.
101,102c97
< datum *
< memTestAddressBus(volatile datum * baseAddress, unsigned long nBytes)
104,106c99,104
<     unsigned long addressMask = (nBytes/sizeof(datum) - 1);
<     unsigned long offset;
<     unsigned long testOffset;
108,109d105
<     datum pattern     = (datum) 0xAAAAAAAA;
<     datum antipattern = (datum) 0x55555555;
110a107,113
112,115c115,123
<      * Write the default pattern at each of the power-of-two offsets.
<     for (offset = 1; (offset & addressMask) != 0; offset <<= 1)
>   testOffset = 0;
117c125
<         baseAddress[offset] = pattern;
118a127
120,123c129,135
<      * Check for address bits stuck high.
<     testOffset = 0;
126c138
128,131c140
<         if (baseAddress[offset] != pattern)
<             return ((datum *) &baseAddress[offset]);
134,143c143
<     baseAddress[testOffset] = pattern;
<      * Check for address bits stuck low or shorted.
<     for (testOffset = 1; (testOffset & addressMask) != 0; testOffset <<= 1)
<         baseAddress[testOffset] = antipattern;
<     if (baseAddress[0] != pattern)
145c145,148
<       return ((datum *) &baseAddress[testOffset]);
148,157c151,152
<             if ((baseAddress[offset] != pattern) && (offset != testOffset))
159c154
<     return (NULL);
>   return (NULL);
163,181c158,176
<  * Function:    memTestDevice()
<  * Description: Test the integrity of a physical memory device by
<  *              performing an increment/decrement test over the
<  *              entire region.  In the process every storage bit
<  *              in the device is tested as a zero and a one.  The
<  *              base address and the size of the region are
<  *              selected by the caller.
<  * Notes:
<  *              incorrect value was read back.  By examining the
>    Notes:
183,184c178
< datum *
< memTestDevice(volatile datum * baseAddress, unsigned long nBytes)
186,187c180,181
<     unsigned long nWords = nBytes / sizeof(datum);
189,190c183,184
<     datum pattern;
<     datum antipattern;
193,199c187,193
<      * Fill memory with a known pattern.
<     for (pattern = 1, offset = 0; offset < nWords; pattern++, offset++)
201,204c195,200
<      * Check each location and invert it for the second pass.
206,212c202
<         antipattern = ~pattern;
<         baseAddress[offset] = antipattern;
215,218c205,215
<      * Check each location for the inverted pattern and zero it.
220,224c217
<         if (baseAddress[offset] != antipattern)
225a219
227c221
<     return (NULL);
>   return (NULL);
234c228,244
<   unsigned int fR=2048;      // 100% of physical RAM
> #define DOT_DIV 1
> #define NL_DIV 128
> #define DOT_DIV 4
> #define NL_DIV 512
> #endif
> #define DOT_DIV 4
> #define NL_DIV 512
236c246,247
<   unsigned long fR=81920L;    // default to ESP8266
242a254,256
245c259,260
<   Serial.begin(115200);
247c262
< // fR begins very large
251c266
253c268
<   Serial.print(fR,DEC);
255c270
<   Serial.print(fR,HEX);
257c272
260c275
263c278
265c280
<   Serial.print(fR-callStack, HEX);    // alloc size less stackframe
269c284
<   Serial.println(stackBot()-callStack, HEX); // limit of testing
272c287,288
< unsigned char i=0;  // global to preserve stack space during testing
274,276d289
<   datum* bad;
<   datum f;
278c291,294
<   if ((f=memTestDataBus((datum *)hT)) != 0) {
>   unsigned char* bad;
>   unsigned char f;
283c299
<   } else if ((bad = memTestAddressBus((datum *)hT, (unsigned long)(fR-callStack))) != NULL) {
288c304
<   } else if ((bad = memTestDevice((datum *)hT, (unsigned long)(fR-callStack))) != NULL) {
294d309
<     Serial.print('.');
296c311,318
<     if ((i % 128) == 0) Serial.println();
>       Serial.print('.');
>       Serial.println();
