Can someone support me on this project? I'm trying to make 4 digital inputs + 4 digital outputs at once on module ESP12E but I'm not able to make it work.
If I disable part of the code for inputs then outputs are working or oposite too however all at once looks to make module bloacket.
Thanks in advance for your help
//ItKindaWorks - Creative Commons 2016
//github.com/ItKindaWorks
//Requires PubSubClient found here: https://github.com/knolleary/pubsubclient
//ESP8266 Simple MQTT light controller
#include <PubSubClient.h>
#include <EEPROM.h>
//EDIT THESE LINES TO MATCH YOUR SETUP
#define MQTT_SERVER "192.168.1.200"
const char* ssid = "JAZZTEL_david";
const char* password = "0102030405060";
// Assign Arduino Friendly Names to GPIO pins
#define D0 16 //
#define D1 5 // I2C Bus SCL (clock)
#define D2 4 // I2C Bus SDA (data)
#define D3 0
// #define D4 2 // Same as "LED_BUILTIN", but inverted logic
#define D5 14 // SPI Bus SCK (clock)
#define D6 12 // SPI Bus MISO
#define D7 13 // SPI Bus MOSI
#define D8 15 // SPI Bus SS (CS)
#define D9 3 // RX0 (Serial console)
#define D10 1 // TX0 (Serial console)
const int internalled = 2; //GPIO 2 internal led
int D0State = 0;
int D1State = 0;
int D2State = 0;
int D3State = 0;
int D5State = 0;
int D6State = 0;
int D7State = 0;
int D8State = 0;
char* Topic = "/test/light";
WiFiClient wifiClient;
// Callback function header
void callback(char* topic, byte* payload, unsigned int length);
PubSubClient client(MQTT_SERVER, 1883,callback, wifiClient);
long lastMsg = 0;
char msg[50];
//initialize the light as an output and set to (off)
pinMode(D0, INPUT);
pinMode(D1,INPUT);
pinMode(D2,INPUT);
pinMode(D3, INPUT);
pinMode (D5, OUTPUT);
pinMode (D6, OUTPUT);
pinMode (D7, OUTPUT);
pinMode (D8, OUTPUT);
EEPROM.begin(512); // Begin eeprom to store on/off state
D5State = EEPROM.read(0);
digitalWrite(D5,D5State);
D6State = EEPROM.read(1);
digitalWrite(D6,D6State);
D7State = EEPROM.read(2);
digitalWrite(D7,D7State);
D8State = EEPROM.read(3);
digitalWrite(D8,D8State);
pinMode(internalled, OUTPUT);
digitalWrite(internalled, HIGH);
//start the serial line for debugging
delay(100);
//start wifi subsystem
WiFi.begin(ssid, password);
//attempt to connect to the WIFI network and then connect to the MQTT server
reconnect();
//wait a bit before starting the main loop
delay(2000);
void loop(){
//reconnect if connection is lost
if (!client.connected() && WiFi.status() == 3) {reconnect();}
//maintain MQTT connection
client.loop();
//MUST delay to allow ESP8266 WIFI functions to run
delay(10);
digitalWrite(internalled, LOW);
void callback(char* topic, byte* payload, unsigned int length) {
//convert topic to string to make it easier to work with
String topicStr = topic;
// Print out some debugging info
Serial.println("Callback update.");
Serial.print("Topic: ");
Serial.println(topicStr);
D0State = digitalRead(D0);
D1State = digitalRead(D1);
D2State = digitalRead(D2);
D3State = digitalRead(D3);
//turn the light on if the payload is '1' and publish to the MQTT server a confirmation message
if (payload[0] == '0'){
digitalWrite(D5, HIGH);
client.publish("/test/light1", "out1 On");
D5State = HIGH;
EEPROM.write(0, D5State); // Write state to EEPROM
EEPROM.commit();
//turn the light off if the payload is '0' and publish to the MQTT server a confirmation message
else if (payload[0] == '1'){
digitalWrite(D5, LOW);
client.publish("/test/light1", "out1 Off");
D5State = LOW;
EEPROM.commit();
//turn the light2 on if the payload is '1' and publish to the MQTT server a confirmation message
else if (payload[0] == '2'){
digitalWrite(D6, HIGH);
client.publish("/test/light1", "out2 On");
D6State = HIGH;
EEPROM.write(1, D6State); // Write state to EEPROM
EEPROM.commit();
//turn the light2 off if the payload is '0' and publish to the MQTT server a confirmation message
else if (payload[0] == '3'){
digitalWrite(D6, LOW);
client.publish("/test/light1", "out2 Off");
D6State = LOW;
EEPROM.commit();
//turn the light3 on if the payload is '1' and publish to the MQTT server a confirmation message
else if (payload[0] == '4'){
digitalWrite(D7, HIGH);
client.publish("/test/light1", "out3 On");
D7State = HIGH;
EEPROM.write(2, D7State); // Write state to EEPROM
EEPROM.commit();
//turn the light3 off if the payload is '0' and publish to the MQTT server a confirmation message
else if (payload[0] == '5'){
digitalWrite(D7, LOW);
client.publish("/test/light1", "out3 Off");
D7State = LOW;
EEPROM.commit();
//turn the light4 on if the payload is '1' and publish to the MQTT server a confirmation message
else if (payload[0] == '6'){
digitalWrite(D8, HIGH);
client.publish("/test/light1", "out4 On");
D8State = HIGH;
EEPROM.write(3, D8State); // Write state to EEPROM
EEPROM.commit();
//turn the light4 off if the payload is '0' and publish to the MQTT server a confirmation message
else if (payload[0] == '7'){
digitalWrite(D8, LOW);
client.publish("/test/light1", "out4 Off");
D8State = LOW;
EEPROM.commit();
//turn the lights off if the payload is '8' and publish to the MQTT server a confirmation message
//else if (payload[0] == '8'){
// digitalWrite(D0, LOW);
//digitalWrite(D1, LOW);
//digitalWrite(D2, LOW);
//digitalWrite(D3, LOW);
//client.publish("/test/light1", "all lights Off");
//client.publish("/test/light1", "out1 Off");
//client.publish("/test/light1", "out2 Off");
//client.publish("/test/light1", "out3 Off");
//client.publish("/test/light1", "out4 Off");
//turn aa the lights on if the payload is '9' and publish to the MQTT server a confirmation message
//else if (payload[0] == '9'){
// digitalWrite(D0, HIGH);
// digitalWrite(D1, HIGH);
//digitalWrite(D2, HIGH);
//digitalWrite(D3, HIGH);
//client.publish("/test/light1", "all lights on");
//client.publish("/test/light1", "out1 On");
//client.publish("/test/light1", "out2 On");
//client.publish("/test/light1", "out3 On");
//client.publish("/test/light1", "out4 On");
if (D0State == HIGH);{
client.publish("/test/light1", "input1");}
if (D1State == HIGH);{
client.publish("/test/light1", "input2");}
if (D2State == HIGH);{
client.publish("/test/light1", "input3");}
if (D3State == HIGH);{
client.publish("/test/light1", "input4");}
void reconnect() {
//attempt to connect to the wifi if connection is lost
if(WiFi.status() != WL_CONNECTED){
//debug printing
Serial.println(ssid);
//loop while we wait for connection
Serial.print(".");
//print out some more debug once connected
Serial.println("");
//-digitalWrite(internalledpin, LOW);
//make sure we are connected to WIFI before attemping to reconnect to MQTT
if(WiFi.status() == WL_CONNECTED){
// Loop until we're reconnected to the MQTT server
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Generate client name based on MAC address and last 8 bits of microsecond counter
String clientName;
clientName += "esp8266-";
uint8_t mac[6];
WiFi.macAddress(mac);
clientName += macToStr(mac);
//if connected, subscribe to the topic(s) we want to be notified about
if (client.connect((char*) clientName.c_str())) {
Serial.print("\tMTQQ Connected");
client.subscribe("/test/light1");
//otherwise print failed for debugging
else{Serial.println("\tFailed."); abort();}
//generate unique name from MAC addr
String macToStr(const uint8_t* mac){
String result;
for (int i = 0; i < 6; ++i) {
result += String(mac[i], 16);
if (i < 5){
result += ':';
return result;
