It is however very easy to set up and use.
First, include the library into your sketch and create a server object:
#include <ESP8266WebServer.h>
ESP8266WebServer server(80);
Next, in your setup function tell the server what URIs it needs to respond to:
server.on("/", [](){
server.send(200, "text/plain", "This is an index page.");
or, which is equivalent:
void handle_index() {
// later, in setup() function:
server.on("/", handle_index);
The first argument is the URI and the second is the function that will be called to respond to this URI.
In that function you need to call
server.send(code, content_type, content)Processing arguments of GET and POST requests is also easy enough. Let's make our sketch turn a led on or off depending on the value of a request argument.
http://<ip address>/led?state=on will turn the led ON
http://<ip address>/led?state=off will turn the led OFF
server.on("/led", []() {
String state=server.arg("state");
if (state == "on") digitalWrite(13, LOW);
else if (state == "off") digitalWrite(13, HIGH);
server.send(200, "text/plain", "Led is now " + state);
The complete example which also shows how to do forms and images is available here:
https://gist.github.com/igrr/3b66292cf8708770f76b.
