I'm trying to save some string variables into EEPROM, like, password, ssid, username and so on but I can't find a perfect way for it. I have a code which doesn't work for me.
if you see any problems in the code please tell me or if you have a code which does actually works, please let me know of it.
P.S. if I put delay(1000) in loops of write_word and read_word functions, the write_word function takes much more time than read_word. I assume that write_word function is writing '0' into EEPROM and read_word reads the first '0' and finishes the function. but I'm not sure.
String read_word(int addr)
String word1;
char readChar;
int i = addr;
while (readChar != '\0')
readChar = char(EEPROM.read(i));
delay(10);
i++;
if (readChar != '\0')
word1 += readChar;
return word1;
void write_word(int addr, String word2)
delay(10);
for (int i = addr; i < word2.length() + addr; ++i) {
Serial.println(word2[i]);
EEPROM.write(i, word2[i]);
EEPROM.write(word2.length() + addr, '\0');
EEPROM.commit();
void init_val(void)
byte initialized = EEPROM.read(initializing);
if (initialized != 124) // it must be 123 but I put 124 here so this part will be run eveytime
EEPROM.write(initializing, 123);
EEPROM.write(ap_st_mode_add, st_mode);
EEPROM.commit();
// note that ap_pass_add and ap_pass_add are defined as 50 and 100 respectively
// ap_pass and ap_ssid are global string variables
String init_pass_ssid = "DEFUALT";
write_word(ap_pass_add, init_pass_ssid);
write_word(ap_ssid_add, init_pass_ssid);
ap_st_mode = EEPROM.read(ap_st_mode_add);
ap_pass = read_word(ap_pass_add);
ap_ssid = read_word(ap_ssid_add);
