I am new in this forum, and I want to ask if somebody can verify my problem or solve it.
I have a simple sketck to check my lcd with I2C. It works, but the cursor keeps blinking. I don't want to see cursor.
#include <Streaming.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
const int MAX_PACKET_SIZE = 101;
char packetBuffer[ MAX_PACKET_SIZE];
LiquidCrystal_I2C lcd(0x3f, 20, 4);
void setup()
Wire.begin(2, 4);
lcd.home();
lcd.setCursor(0, 1);
lcd.print(" Setup ...");
Serial.println(" Setup ...");
strcpy(packetBuffer, "Pool 28.6 Erw. 0.0 Sonne 21.6 Ret. 26.8Luft 25.6 Vor. 27.2Pumpe 0 Wind 1.86");
Serial << packetBuffer << endl;
lcd.setCursor(0, 0);
lcd << packetBuffer ;
delay(2000);
lcd.noCursor();
void loop(){}
The text appears, but after the delay the diplay clears and hangs up. After a reset no more text on the display, I have to disconnect the power to make work the display again.
The same happens with other options, like cursor_off etc.
I think that is a problem with the library. Which one does work well?
I hope you understand what I mean, english is not my native language.
