Here is small sketch allowing to connect two androids clients on a single ESP8266.
The server is on ESP
/* Create a WiFi access point and provide a web server on it. */
#include <WiFiClient.h>
/* Set these to your desired credentials. */
const char *ssid = "JP_TestAP";
int status = WL_IDLE_STATUS;
boolean alreadyConnected[2] ; // whether or not the client was connected previously
WiFiServer server(23);
WiFiClient client[2];
void setup()
delay(1000);
Serial.print("Configuring access point...");
/* You can remove the password parameter if you want the AP to be open. */
WiFi.softAP(ssid);
delay(10000);
Serial.print("AP IP address: ");
Serial.println(myIP);
Serial.println("\nStarting server...");
// start the server:
server.begin();
void loop()
unsigned int i;
for (i= 0; i<2; i++)
// wait for a new client:
if (!client[i])
client[i] = server.available();
if (client[i].status() == CLOSED)
client[i].stop();
Serial.println("connection closed on client " );
Serial.print(i);
if (!alreadyConnected[i]) // when the client sends the first byte, say hello:
// clead out the input buffer:
client[i].flush();
Serial.println("new client ");
client[i].println("Hello, client !");
Serial.print(i);
alreadyConnected[i] = true;
if (client[i].available() > 0)
// read the bytes incoming from the client:
char thisChar = client[i].read();
// echo the bytes back to the client:
client[i].println(thisChar);
// echo the bytes to the server as well:
Serial.write(thisChar);
You can test it with Socket Protocol App free on GooglePlay
JP
