By mhmd.shato89
#37515 Hello
I tried an example about webserver
const char* ssid = "your-ssid";
const char* password = "your-password";
int ledPin = 2; // GPIO2
WiFiServer server(80);
delay(10);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
if (!client) {
return;
Serial.println("new client");
while(!client.available()){
delay(1);
String request = client.readStringUntil(‘\r’);
Serial.println(request);
client.flush();
// Match the request
int value = LOW;
if (request.indexOf("/LED=ON") != -1) {
digitalWrite(ledPin, HIGH);
value = HIGH;
if (request.indexOf("/LED=OFF") != -1) {
value = LOW;
// Set ledPin according to the request
//digitalWrite(ledPin, value);
// Return the response
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.print("Led pin is now: ");
if(value == HIGH) {
client.print("On");
} else {
client.print("Off");
client.println("<br><br>");
client.println("Click <a href=\"/LED=ON\">here</a> turn the LED on pin 2 ON<br>");
client.println("Click <a href=\"/LED=OFF\">here</a> turn the LED on pin 2 OFF<br>");
client.println("</html>");
delay(1);
Serial.println("Client disonnected");
Serial.println("");
All is good with no problem of uploading
On serial port I found the following text ( all is connected ):
Connecting to My Wireless
WiFi connected
Server started
Use this URL to connect: http://192.168.1.99/
When I entered the ip 192.168.1.99 always it's unreachable.
I tried ping 192.168.1.99 =>destination unreachable.
thank you
please help
By blackled
#37684 happy new year !
Did your code compile without errors ?
I used cour code and got an compile error in this line:
String request = client.readStringUntil('\r');
than I've changed it to:
String request = client.readStringUntil(0x13);
after this it compiled without errors.
After uploading to ESP... it worked fine !
By secu
#38049
blackled wrote:happy new year !
Hi guys,
Happy new year!!
I am interested to pass the anterior WEBSERVER example to AccesPoint. I mean, i want to make my ESP8266 Board autonomous and not depend to my home router, so fix and IP like 192.168.4.1 and for example to make ON the light type 192.168.4.1/LED=ON.
So i would like to create a SSID and Password for the ESP8266 and then run like web server example, ANY IDEA?? :roll: :roll: :roll:
THANKS A LOT!
By Rigor_M
#40849 Hi,
i'm having the same problem, I have a ESP8266-07, grounded GPIO15 and GPIO0, uploaded the example sketch. no problem.
I see the same thing in the serial console. but when I go the the ip adress, http://192.168.250.171/ in my case, I get a timeout.
also can't ping the IP but I think that the ICMP protocol is not implemented in the SDK.
Anyone could point me (and others in this thread) in the right direction ?
