its a 12E but I still haven't worked out how to use pins 9,10 without causing a reset.
So I need SPI to write to the SD card.
I have a slave PRO mini that can translate and save the datalog but I wanted a history buffer to display on my LCD that is currently connected to the ESP8266-12e
I also wanted to put a rotary encoder on there so I can scroll through the history on the LCD.
I was planning to move all the LCD code to the pro mini, but only because I ran out of pins. The ESP seems to be handling the lot at the moment.
I have 2pins(RTC 20x4LCD) 3pins(TM1638qyf) and 1pin(5xds18b20's).
I have pin 16, 0, and 15 free. I wanted to keep pin 16 available for the "deep sleep" modes that I want to utilise to save power.
So can I use an 12c pin expander to create some extra pins to use for the spi?
or is that naf? and stupid and unwise?
