By nuesome
#47623 /*this is the client code i am running/ it has only about a 1 sec. latency to make it to esp#1/webserver so i guess thats not bad. But it keeps connecting and disconnecting to the server after message is sent. Also, I see the websocket server and client examples on arduino ide but I am new to programming and not sure how to program the payload code. In other words how to say "if pir high turn on pinX at server/esp1
* This sketch sends a message to a TCP server
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti WiFiMulti;
int ledPin = 3;
int inputPin = 2;
int pirState = LOW;
int val = 0;
delay(10);
pinMode(ledPin, OUTPUT);
pinMode(inputPin, INPUT);
WiFiMulti.addAP("JP", "passpasspass");
Serial.print("Wait for WiFi... ");
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.println("");
const uint16_t port = 80;
const char * host = "192.168.1.241"; // ip or dns
// val = digitalRead (inputPin);
Serial.println(host);
WiFiClient client;
if (!client.connect(host, port)) {
Serial.println("wait 5 sec...");
delay(5000);
return;
if (val == HIGH){
client.print("/gpio/0"); //this is command to turn led on at the webserver
digitalWrite (ledPin, HIGH);}//this is led on this esp
else {client.print("/gpio/1");//this is command to turn led off at webserver
digitalWrite (ledPin, LOW);}
//read back one line from server
client.println(line);
// Serial.println("closing connection");
// client.stop();
// Serial.println("wait 5 sec...");
// delay(5000);
[code][/code]
By eduperez
#47645 I do not see the problem with opening a new connection each time the PIR detects some movement, you do not seem to have any tight schedule if you wait for five seconds between checks.
On the other hand, you seem to be opening a new connection irregardless of the PIR status, why don't you put the "client.connect" code inside the "if (val == HIGH)" condition?
On the other hand, you could use the schema at viewtopic.php?f=11&t=4458 to wake up the client when the PIR detects some movement.
