By rodmcm
#50337 If I use
char Ssid[ ] = "mySSID";
char Password[ ] = "mypassword";
and
WiFi.begin (Ssid,Password);
I get a reliable connection
If I assign set up variables char Ssid[20 ]; and char Password [20 ]; and populate them with the same Ssid and Password names via Serial.read(), then I cannot get a connection even though the remaining characters in the arrays are Null, as would be expected with the end of a string.
I have tried making sure both arrays have values in them before enabling WIFI.begin... No luck either
Any thoughts or has anyone done this. What I am doing is Using a Nextion for the user to enter their SSID and password and return to them the IP address as connected.
By martinayotte
#50342 I can't believe that both behaviours are not the same, simply because in WiFi.begin() both SSID and Password are copied using strcpy() into station_config structure.
It must be some stupid mistake in your code, such as you are not removing "\r\n" from Serial input.
