vanjo9800 wrote:Thank you awinterstale33!!!
ESP-NOW seems as a very good solution to the problem. It is secure and developed for ESP8266 in particular. I will give it a try.
However, it seems that I cannot manage to run it with Arduino IDE because it does not recognize the espnow library.
This code: https://github.com/cho45/esp8266-esp-no ... c/main.cpp
Gives the following errors: undefined reference to `esp_now_init' and so on about all other elements from espnow.h.
Do you know how I can fix that?
Hi Vanjo. where did you find the library in the first place? Thanks!
Layup wrote:Hi Vanjo. where did you find the library in the first place? Thanks!
https://github.com/jeelabs/esp-link
