So couple of days ago i recieved my ESP-07 modules, cause i wanted to play with the external antenna's boost some range, however,
using the AP example in the IDE the ESP-07 does not setup a AP, The same code does work on the ESP-12 ,
Any suggestions,
All pins are connected correctly
Orcanbull
Yes i can help you , Yes you can send me a PM with a question - No i won't make the code for you
