By RichardS
#56965 Really need help with this!
Driving me mad, can not track down the reason spiffs is doing this, the test sketch operates fast each and every time no matter what, the same functions within another sketch and.... its SLOOOOOOW!
RichardS
By mrburnette
#57070 Sounds like a cache problem, IMO.
I have not looked into the SPIFFS code, but when a simple sketch works perfectly and a complex sketch does not work "as fast" the most probable cause is likely ICACHE is congested and 'thrashing'.
Ray
By RichardS
#57071
mrburnette wrote:Sounds like a cache problem, IMO.
Ray
Can anything be done about it?
RichardS
