I have what I had hoped would be a simple project, but it hasn't worked out that way. I could really use some advice. If I have come to the wrong forum, please direct me where I should be asking this.
I am designing a simple house alarm with four door/window inputs and a chime, siren and strobe output. I threw together a PCB and I am having several problems. I have attached the schematic and code.
1st: Adafruit Huzzah Feather keeps locking up. I can only program it off of the PCB as it doesn't want to program at all on the PCB. It seems to be locking up during the main "else" statement.
2nd: I am getting weird results from the Blynk portion of the code. Maybe I am not understanding how it all works although I think I have a pretty good idea.
Please don't laugh at my code, but if you see any serious mistakes please let me know.
Blynk is a platform with iOS and Android apps to control
Arduino, Raspberry Pi and the likes over the Internet.
You can easily build graphic interfaces for all your
projects by simply dragging and dropping widgets.
Downloads, docs, tutorials: http://www.blynk.cc
Blynk community: http://community.blynk.cc
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
Blynk library is licensed under MIT license
This example code is in public domain.
This example runs directly on ESP8266 chip.
Note: This requires ESP8266 support package:
https://github.com/esp8266/Arduino
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
Change WiFi ssid, pass, and Blynk auth token to run :)
#define BLYNK_PRINT Serial // Comment this out to disable prints and save space
#include <BlynkSimpleEsp8266.h>
//variables and WIFI credentials
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "4d422895f8bc4f2294b79edc93fa0e02";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "Sid";
char pass[] = "password";
//unchanging variables
const int alarmPin1 = 15; //reed switches for the doors
const int alarmPin2 = 13;
const int alarmPin3 = 12;
const int alarmPin4 = 14;
const int chimePin = 4; //chime beeps when door is opened
const int sirenPin = 5; //siren screams when door is opened
//variables
int armState = 0;
int chimeState = 1; //state of the chime pin
int sirenState = 0; //state of the siren pin
int buttonState1 = 0; //State of the reed switches
int buttonState2 = 1;
int buttonState3 = 1;
int buttonState4 = 1;
int chimedOnce = 0; //activate/deactivate the chime pin
// Main setup
void setup()
Serial.begin(57600);
Blynk.begin(auth, ssid, pass);
pinMode(alarmPin1, INPUT); //sets alarmPin1 as an input pin
pinMode(alarmPin2, INPUT); //sets alarmPin2 as an input pin
pinMode(alarmPin3, INPUT); //sets alarmPin3 as an input pin
pinMode(alarmPin4, INPUT); //sets alarmPin4 as an input pin
pinMode(chimePin, OUTPUT); //sets chimePin as output
//pinMode(sirenPin, OUTPUT); //sets sirenPin as output
//Blynk Functions (virtual pins)
BLYNK_WRITE(V10) { // reads state of virtual arming button on app
armState = param.asInt(); // sets the variable = to that state
BLYNK_WRITE(V0) { // reads state of virtual chime switch on app
chimeState = param.asInt(); // sets the variable = to that
BLYNK_WRITE(V7) { // reads state of virtual siren switch on app
sirenState = param.asInt(); // sets the variable = to that
// Main Loop
Blynk.run();
Serial.println(armState);
buttonState1 = digitalRead(alarmPin1); // check state of reed switch
//buttonState2 = digitalRead(alarmPin2); // check state of reed switch
//buttonState3 = digitalRead(alarmPin3); // check state of reed switch
//buttonState4 = digitalRead(alarmPin4); // check state of reed switch
if (armState == 0) { //alarm not armed
sirenState = 0;
if (buttonState1 == HIGH) { //closed door #1
Blynk.virtualWrite(V1, 0); //turns virtual LED off in app
chimedOnce = 0;
else { //open door
Blynk.virtualWrite(V1, 1023); //turns virtual LED on in app
if (chimedOnce == 0) {
if (chimeState == 1) {
chimeBeeps();
chimedOnce = 1;
/*if (buttonState2 == HIGH) { //closed door #2
Blynk.virtualWrite(V2, 0); //turns virtual LED off in app
chimedOnce = 0;
else { //open door
Blynk.virtualWrite(V2, 1023); //turns virtual LED on in app
chimeBeeps();
chimedOnce = 1;
if (buttonState3 == HIGH) { //closed door #3
Blynk.virtualWrite(V3, 0); //turns virtual LED off in app
chimedOnce = 0;
else { //open door
Blynk.virtualWrite(V3, 1023); //turns virtual LED on in app
chimeBeeps();
chimedOnce = 1;
if (buttonState4 == HIGH) { //closed door #4
Blynk.virtualWrite(V4, 0); //turns virtual LED off in app
chimedOnce = 0;
else { //open door
Blynk.virtualWrite(V4, 1023); //turns virtual LED on in app
chimeBeeps();
chimedOnce = 1;
else {
if (armState == 1) {
chimedOnce = 0;
else { //open door
do {
sirenScream(); //alarm screams
} while (sirenState == 1);
chimeBeeps();
chimedOnce = 1;
chimedOnce = 0;
else { //open door
chimeBeeps();
chimedOnce = 1;
chimedOnce = 0;
else { //open door
chimeBeeps();
chimedOnce = 1;
chimedOnce = 0;
else { //open door
chimeBeeps();
chimedOnce = 1;
//user defined functions
void chimeBeeps() {
digitalWrite (chimePin, HIGH);
delay (100);
digitalWrite (chimePin, LOW);
delay (100);
delay (100);
delay (100);
delay (100);
delay (100);
void sirenScream() {
delay (500);
delay (100);
