- Fri Jan 06, 2017 10:14 pm
#60572
Hello,
I have a project that uses JavaScript, maybe these excerpts will help.
In a header file named PAGE_ajax.js.h,
Code: Select allconst char PAGE_ajax_js[] PROGMEM = R"=====(
var xmlHttp = createXmlHttpObject();
function createXmlHttpObject()
if(window.XMLHttpRequest)
xmlHttp=new XMLHttpRequest();
else
xmlHttp=new ActiveXObject('Microsoft.XMLHTTP');
return xmlHttp;
function processInfo()
if(xmlHttp.readyState==0 || xmlHttp.readyState==4)
xmlHttp.open('POST','xmlInfo',true);
xmlHttp.onreadystatechange=handleServerResponseInfo;
xmlHttp.send(null);
setTimeout('processInfo()',1000);
function handleServerResponseInfo()
if(xmlHttp.readyState==4 && xmlHttp.status==200)
var xmlDoc = xmlHttp.responseXML;
var rssi = xmlDoc.getElementsByTagName("xRSSI")[0].childNodes[0].nodeValue;
var recon = xmlDoc.getElementsByTagName("xWiFiRecon")[0].childNodes[0].nodeValue;
var rtime = xmlDoc.getElementsByTagName("xRunTime")[0].childNodes[0].nodeValue;
var Heap = xmlDoc.getElementsByTagName("xHeap")[0].childNodes[0].nodeValue;
var DocObj = document.getElementById('idRSSI');
DocObj.innerHTML=rssi;
var DocObj = document.getElementById('idWiFiRecon');
DocObj.innerHTML=recon;
var DocObj = document.getElementById('idHeap');
DocObj.innerHTML=Heap;
var DocObj = document.getElementById('idRunTime');
DocObj.innerHTML=rtime;
The js file is included in a webpage like this, in a file named PAGE_Info.h
Code: Select allconst char PAGE_Info_Head[] = R"=====(
<!DOCTYPE html>
<head>
<title>Information</title>
<link rel="stylesheet" type="text/css" href="style.css">
<meta charset="utf-8" />
<script src="ajax.js"></script>
</head>
/* Place this at the top of the HTML body */
const char PAGE_Info_Menu[] = R"=====(
<div id="Menu">
<ul>
<li><a href="PAGE_Door_Status">Home</a></li>
<li><a href="PAGE_History">History</a></li>
<li class="active"><a href="PAGE_Info">Information</a></li>
<li><a href="PAGE_WiFi_Settings">WiFi Settings</a></li>
</ul>
</div>
The header files are include in the .ino file as,
Code: Select all// Include the HTML Pages
#include "Page_Style.css.h"
#include "PAGE_ajax.js.h"
#include "Page_Door_Status.h"
#include "Page_History.h"
#include "Page_Info.h"
#include "Page_WiFi_Settings.h"
And the URLs are assigned handlers in Setup() like this,
Code: Select allvoid setup( void )
CommInit();
// Initialize I2C
Wire.begin(I2C_SDA, I2C_SCL);
// Configure I/O of PCA9536 I2C 4-bit Port Expander.
PCA9536_ConfigureSet( PCA9536_IO_CNFG );
StartWiFiSTA();
server.on( "/xmlHome", HandleXML_Home );
server.on( "/xmlInfo", HandleXML_Info );
server.on( "/style.css", HandleStyleSheet );
server.on( "/ajax.js", HandleJavaScript );
server.on( "/", HandleDoorStatus );
server.on( "/PAGE_Door_Status", HandleDoorStatus );
server.on( "/PAGE_History", HandleHistory );
server.on( "/PAGE_Info", HandleInfo );
server.on( "/PAGE_WiFi_Settings", Handle_WiFi_Settings );
server.on( "/favicon.ico", HandleFavoriteIcon );
server.onNotFound( HandleNotFound );
server.begin();
Serial.println( "HTTP server started" );
UtilityHeapMonitorInit();
// Start the Periodic ISR, and assign a callback function
Periodic.attach_ms( 100, PeriodicISR );
Serial.println( "Type 'help' for Comm Menu Commands" );
EventLogAdd( EVENT_INIT_DONE );
Handler functions for the js looks like this:
Code: Select allstatic void HandleJavaScript( void )
server.send( 200, "text/plain", PAGE_ajax_js );
yield();
Serial.println("Handle ajax.js");
yield();
Best Regards,
GregryCM
