perigalacticon wrote:I tried uploading SPIFFS files for the first time by using: Tools / Esp8266 Sketch Data Upload and I was surprised to see that it took more than 5 minutes to upload. I used the 3M SPIFFS option. Is this normal / expected? Can it be improved?
I was doing some tests with large image files loaded into 3M SPIFFS. Because of how long it took I took a slightly different route. I would load a sketch that supported OTA uploads. I would then do the SPIFFS upload through the OTA connection. That was a lot faster than serial. But that was when I was stuck using 115200 baud for serial connections.
