I need a bit of help.
My project is up and running its a 3 phase wind turbine charging 4x 12V battery's.
I want to add serial communication between the Arduino Nano that is controlling PWM to slow the turbine and an esp8266 to upload data to BLYNK IOT
I am using the Arduino nano as the main controller as it is MISSION CRITICAL i.e. if that code blocks bye bye turbine and battery bank.
A logic level shiftier 5v to 3.3v is fitted between tx rx lines.
I am only able to pass my variable data (the battery voltage) once to the esp8266 then it will not update any more.
If someone could have a look at my code and give me some advice, I would be grateful.
Arduino code
//wind turbine ARDUINO code
#include <EasyTransfer.h>
//create two objects
EasyTransfer ETin, ETout;
struct RECEIVE_DATA_STRUCTURE{
//put your variable definitions here for the data you want to receive
//THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
// int16_t Voltage;
int16_t data1;
int16_t data2;
struct SEND_DATA_STRUCTURE{
int16_t Voltage;
//give a name to the group of data
RECEIVE_DATA_STRUCTURE rxdata;
SEND_DATA_STRUCTURE txdata;
#include <Timer.h>
//http://www.doctormonk.com/2012/01/arduino-timer-library.html
Timer t;
#include <LiquidCrystal_I2C.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads; /* Use this for the 16-bit version */
//Adafruit_ADS1115 ads1115(0x48); // construct an ads1115 at address 0x48
float volt0, volt1, volt2, volt3, voltage;
//int voltagePin = A0; //connect to voltage divider on main battery voltage
int pwmPin = 6; //connect to driver for cooling fan
// int currentPin = A1; //connect to current sensor
int fanPin = 9; // connect to fan
double voltageRegOn; //
int pwmAmount; // store pwm value
double batteryVoltage; //store battery voltage
double currentVoltage; //store current sensor raw voltage
double amps; //store calculated amps
Serial.begin(2400);
//start the library, pass in the data details and the name of the serial port. Can be Serial, Serial1, Serial2, etc.
ETin.begin(details(rxdata), &Serial);
ETout.begin(details(txdata), &Serial);
ads.begin();
// The ADC input range (or gain) can be changed via the following
// functions, but be careful never to exceed VDD +0.3V max, or to
// exceed the upper and lower limits if you adjust the input range!
// Setting these values incorrectly may destroy your ADC!
// ADS1015 ADS1115
// ads.setGain(GAIN_TWOTHIRDS); // 2/3x gain +/- 6.144V 1 bit = 3mV 0.1875mV (default)
// ads.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 2mV 0.125mV
// ads.setGain(GAIN_TWO); // 2x gain +/- 2.048V 1 bit = 1mV 0.0625mV
// ads.setGain(GAIN_FOUR); // 4x gain +/- 1.024V 1 bit = 0.5mV 0.03125mV
// ads.setGain(GAIN_EIGHT); // 8x gain +/- 0.512V 1 bit = 0.25mV 0.015625mV
// ads.setGain(GAIN_SIXTEEN); // 16x gain +/- 0.256V 1 bit = 0.125mV 0.0078125mV
voltageRegOn = 27.6; //set regulator start voltage here
// Wire.begin(0, 2); //define pin for scl sda D3 D4 (gpio)
lcd.begin(20,4);
lcd.backlight();
lcd.setCursor(0,0); //Start at character 0 on line 0
lcd.print("Booting Up....Arduino NANO code");
delay (1000);
lcd.clear();
void takeReadings () {
int16_t adc0, adc1, adc2, adc3;
adc0 = ads.readADC_SingleEnded(0);
adc1 = ads.readADC_SingleEnded(1);
adc2 = ads.readADC_SingleEnded(2);
adc3 = ads.readADC_SingleEnded(3);
// Serial.print("AIN0: "); Serial.println(adc0);
// Serial.print("Volt3: "); Serial.println(voltage);
// Serial.print("PWM: "); Serial.println(pwmAmount);
// Serial.print("AIN1: "); Serial.println(adc1);
// Serial.print("AIN2: "); Serial.println(adc2);
// Serial.print("AIN3: "); Serial.println(adc3);
// Serial.println(" ");
//volt3 = adc0*0.0001875; // Volts
//volt3 = (volt3 *6);
voltage = adc0*0.00113088; //30/26528 measured at pentomiter 30v
volt2 = adc1;
void oneSecond () {
//FAN CODE to turn on DUMP LOAD cooling fan.
if (pwmAmount >= 50){
analogWrite(fanPin,100);
else {
analogWrite(fanPin,0);
lcd.print("Volts:");
lcd.setCursor(6,0); //Start at character 0 on line 0
lcd.print(voltage);
lcd.setCursor(0,1); //Start at character 0 on line 0
lcd.print("AmpsV: ");
lcd.setCursor(7,1); //Start at character 0 on line 0
//lcd.print(amps);
lcd.print(currentVoltage);
lcd.setCursor(0,2); //Start at character 0 on line 0
lcd.print("PWM: ");
lcd.setCursor(7,2); //Start at character 0 on line 0
//lcd.print(amps);
lcd.print(pwmAmount);
void TxRx (){
// txdata.buttonstate = HIGH;
txdata.Voltage = voltage;
//then we will go ahead and send that data out
ETout.sendData();
//there's a loop here so that we run the recieve function more often then the
//transmit function. This is important due to the slight differences in
//the clock speed of different Arduinos. If we didn't do this, messages
//would build up in the buffer and appear to cause a delay.
for(int i=0; i<5; i++){
//remember, you could use an if() here to check for new data, this time it's not needed.
ETin.receiveData();
//Voltage = rxdata.Voltage
//set our LED on or off based on what we received from the other Arduino
// digitalWrite(13, rxdata.buttonstate);
t.update();
int afterOneSecond = t.every(50, oneSecond);
// int afterOneMilliSecond = t.every(1,oneMilliSecond);
int afterTakeReadings = t.every(50,takeReadings);
int afterTxRx = t.every(50,TxRx);
// Apply a load to slow wind turbine if battery bank is fully charged (set by voltageRegOn)
//while
if ( voltage > voltageRegOn && pwmAmount <255){
pwmAmount = pwmAmount +15;
analogWrite(pwmPin,pwmAmount); //send output to mosfet
if ( voltage < voltageRegOn && pwmAmount >0){
pwmAmount = pwmAmount -15;
ESP8266 code
//ESP8266 NODEMCU CODE
//http://www.billporter.info/2011/05/30/easytransfer-arduino-library/comment-page-12/#comments
int16_t Voltage;
int16_t data1;
int16_t data2;
// http://www.billporter.info/2011/05/30/easytransfer-arduino-library/comment-page-12/#comments
int Voltage;
int temp;
#include <Timer.h>
Timer t;
// #define BLYNK_PRINT Serial // Comment this out to disable prints and save space
#include <BlynkSimpleEsp8266.h>
// Attach virtual serial terminal to Virtual Pin V10
//WidgetTerminal terminal(V10);
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "22ce317618cc4f7cb4c99d9b11b8a1fc";
#include <Wire.h>
temp=0;
lcd.begin(20,4);
lcd.backlight();
lcd.print("Booting Up....");
delay (1000);
lcd.clear();
Serial.begin(2400);
Blynk.begin(auth, "FRITZ!Box 7490", "40253267300484638395");
void blinkV (){
//terminal.print("PWM: ");
// terminal.print(pwmAmount);
// terminal.println(); //new line
// Ensure everything is sent
// terminal.flush();
Blynk.virtualWrite(2,rxdata.Voltage); // Volts
void oneSecond() //runs every one second
lcd.print("Volts: ");
lcd.setCursor(8,0); //Start at character 0 on line 0
lcd.print(rxdata.Voltage);
Blynk.virtualWrite(1,temp); // Volts
temp++;
void TxRx (){
ETout.sendData();
ETin.receiveData();
Voltage = rxdata.Voltage;
Blynk.run();
t.update();
int afterOneSecond = t.every(1000, oneSecond);
//int afterOneMilliSecond = t.every(1, oneMilliSecond);
int afterBlinkV = t.every(6000, blinkV);
int afterTxRx = t.every(2500,TxRx);
