Could someone made something like this?
I like to add display OTA result after upload skrech.
Now, the result is only:
case HTTP_UE_TOO_LESS_SPACE:
return F("Not Enough space");
case HTTP_UE_SERVER_NOT_REPORT_SIZE:
return F("Server Did Not Report Size");
case HTTP_UE_SERVER_FILE_NOT_FOUND:
return F("File Not Found (404)");
case HTTP_UE_SERVER_FORBIDDEN:
return F("Forbidden (403)");
case HTTP_UE_SERVER_WRONG_HTTP_CODE:
return F("Wrong HTTP Code");
case HTTP_UE_SERVER_FAULTY_MD5:
return F("Wrong MD5");
case HTTP_UE_BIN_VERIFY_HEADER_FAILED:
return F("Verify Bin Header Failed");
case HTTP_UE_BIN_FOR_WRONG_FLASH:
return F("New Binary Does Not Fit Flash Size");
How to add information about flash size, size of file etc form this function:
HTTPUpdateResult ESP8266HTTPUpdate::handleUpdate(HTTPClient& http, const String& currentVersion, bool spiffs)
HTTPUpdateResult ret = HTTP_UPDATE_FAILED;
// use HTTP/1.0 for update since the update handler not support any transfer Encoding
http.useHTTP10(true);
http.setTimeout(8000);
http.setUserAgent(F("ESP8266-http-Update"));
http.addHeader(F("x-ESP8266-STA-MAC"), WiFi.macAddress());
http.addHeader(F("x-ESP8266-AP-MAC"), WiFi.softAPmacAddress());
http.addHeader(F("x-ESP8266-free-space"), String(ESP.getFreeSketchSpace()));
http.addHeader(F("x-ESP8266-sketch-size"), String(ESP.getSketchSize()));
http.addHeader(F("x-ESP8266-sketch-md5"), String(ESP.getSketchMD5()));
http.addHeader(F("x-ESP8266-chip-size"), String(ESP.getFlashChipRealSize()));
http.addHeader(F("x-ESP8266-sdk-version"), ESP.getSdkVersion());
This is from:
Arduino15\packages\esp8266\hardware\esp8266\2.4.0\libraries\ESP8266httpUpdate\src\ESP8266httpUpdate.cpp
How after error update i can display this information on the ota site, to check correct flash etc..?
Regards
