I2C don't seems to work on Wemos D1 mini and BMP180 shield, running an i2c scanner sketch works if you search a range of address but it if you only search for 1(or 2) address it returns a NACK.
BMP180 is on 0x77. error code return was 2.
Been trying various different ways to get it to work without success. any help is appreciated.
Terence.
Sketch for testing.
#include <Wire.h>
void setup()
//D1 - SCL
//D2 - SDA
Wire.begin();
Serial.begin(9600);
while (!Serial); // Leonardo: wait for serial monitor
Serial.print("\nI2C Scanner : ");
//0:success
//1 : data too long to fit in transmit buffer
//2 : received NACK on transmit of address
//3 : received NACK on transmit of data
//4 : other error
void loop()
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for (address = 0x75; address < 0x78; address++)
Wire.beginTransmission(address);
error = Wire.endTransmission();
Serial.print("error = ");
Serial.println(error);
Wire.flush();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address, HEX);
Serial.println(" !");
nDevices++;
else if (error == 4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address, HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
else
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
