By José Curva
#81038 Hello, I'm trying to change the factory address of a MLX90614. I'm using the NodeMCU ESP-12e with the Arduino IDE. I tried running the code in this link https://chrisramsay.co.uk/posts/2017/09/arduino-and-multiple-mlx90614-sensors-take-two/ . However, I can't run the i2cmaster.h library, since I get the error:
In file included from C:\Users\josec\Desktop\mudar_address_MLX1\mudar_address_MLX1.ino:5:0:
C:\Users\josec\Documents\Arduino\libraries\I2Cmaster/i2cmaster.h:88:20: fatal error: avr/io.h: No such file or directory
#include <avr/io.h>
compilation terminated.
exit status 1
Erro ao compilar para a placa NodeMCU 1.0 (ESP-12E Module). [translation: error compiling for NodeMCU 1.0 (ESP-12E Module) board]
I've researched through the web and I found out that the i2cmaster.h library only works in boards with AVR architecture, which is not the case of the NodeMCU. Is ther an alternative to change the address of the MLX90614?
Thank you all
