By Wouter
#82495 I'm trying to debug a large sketch, I'm occasionally getting a crash related to the web interface, and am trying to find out where exactly this is going wrong.
The stack trace ends with:
Code: Select all    last failed alloc call: 4022D552(1480)
This particular address is not present in the decode stack trace itself, but may hold the key to finding the source of the problem. Any suggestions on how to track this one down?
Code: Select all Decoding 36 results
    0x402222c5: BearSSL::WiFiClientSecure::_installClientX509Validator() at /home/wouter/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/xtensa-lx106-elf/include/c++/4.8.2/bits/shared_ptr_base.h line 986
    :  (inlined by) ?? at /home/wouter/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/xtensa-lx106-elf/include/c++/4.8.2/bits/shared_ptr.h line 316
    :  (inlined by) ?? at /home/wouter/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/xtensa-lx106-elf/include/c++/4.8.2/bits/shared_ptr.h line 598
    :  (inlined by) ?? at /home/wouter/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/xtensa-lx106-elf/include/c++/4.8.2/bits/shared_ptr.h line 614
    :  (inlined by) BearSSL::WiFiClientSecure::_installClientX509Validator() at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.cpp line 877
    0x40222cfc: BearSSL::WiFiClientSecure::_connectSSL(char const*) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.cpp line 962
    0x40219c70: esp_yield at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/core_esp8266_main.cpp line 91
    0x4021a8c3: delay at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/core_esp8266_wiring.cpp line 54
    0x40206d6d: WiFiClient::connect(IPAddress, unsigned short) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/ESP8266WiFi/src/include/ClientContext.h line 136
    :  (inlined by) WiFiClient::connect(IPAddress, unsigned short) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/ESP8266WiFi/src/WiFiClient.cpp line 170
    0x40222eed: BearSSL::WiFiClientSecure::connect(char const*, unsigned short) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.cpp line 231
    0x40225230: BearSSL::PrivateKey::getEC() const at ?? line ?
    0x40216b5c: HTTPClient::connect() at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/ESP8266HTTPClient/src/ESP8266HTTPClient.cpp line 1165
    0x4021c16e: uart_write at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/uart.cpp line 498
    0x40217820: HTTPClient::sendRequest(char const*, unsigned char*, unsigned int) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/ESP8266HTTPClient/src/ESP8266HTTPClient.cpp line 655
    0x40217d98: HardwareSerial::write(unsigned char const*, unsigned int) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/HardwareSerial.h line 158
    0x40273eba: sleep_reset_analog_rtcreg_8266 at ?? line ?
    0x402180a5: Print::write(char const*) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/Print.h line 60
    0x40217d83: HardwareSerial::write(unsigned char) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/HardwareSerial.h line 154
    0x402179ba: HTTPClient::GET() at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/ESP8266HTTPClient/src/ESP8266HTTPClient.cpp line 575
    0x402118e8: HydroMonitorLogging::sendPostData(char*) at /home/wouter/Arduino/libraries/HydroMonitor/src/HydroMonitorLogging.cpp line 730
    0x40225470: BearSSL::PrivateKey::getEC() const at ?? line ?
    0x4022c4c0: _vsprintf_r at /home/earle/src/esp-quick-toolchain/repo/newlib/newlib/libc/stdio/vsprintf.c line 65
    0x4022000a: spiffs_object_truncate at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/spiffs/spiffs_nucleus.cpp line 1727
    0x40211d41: HydroMonitorLogging::transmitMessages() at /home/wouter/Arduino/libraries/HydroMonitor/src/HydroMonitorLogging.cpp line 337
    0x40211caa: HydroMonitorLogging::transmitMessages() at /home/wouter/Arduino/libraries/HydroMonitor/src/HydroMonitorLogging.cpp line 326
    0x40204dab: handleAPI() at /home/wouter/Arduino/Williams_fridge/Fridge_control/webAPI.ino line 149
    0x402251c8: BearSSL::PrivateKey::getEC() const at ?? line ?
    0x40218130: Print::println() at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/Print.cpp line 178
    0x402121b5: HydroMonitorLogging::logData() at /home/wouter/Arduino/libraries/HydroMonitor/src/HydroMonitorLogging.cpp line 250
    0x40224948: Print::write(char) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/Print.h line 73
    0x40218114: Print::print(char) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/Print.cpp line 126
    0x402106f4: HydroMonitorIsolatedSensorBoard::readSensor(bool) at /home/wouter/Arduino/libraries/HydroMonitor/src/HydroMonitorIsolatedSensorBoard.cpp line 36
    0x40207a07: TwoWire::requestFrom(int, int) at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/Wire/Wire.cpp line 134
    0x402042f9: loop at /home/wouter/Arduino/Williams_fridge/Fridge_control/loop.ino line 36
    0x40219d20: loop_wrapper() at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/core_esp8266_main.cpp line 125
    0x401015d5: cont_wrapper at /home/wouter/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/cont.S line 81
Note: also asked on StackOverflow and opened issue about the same on github.
