By AbaZum
#82760 Hello!
Is there a possibility to configure my router with port forwarding and DDNS after i connect the esp8266 to it?
I've used WiFiManager and connect my esp8266 to my router. I want when it connect to save in my router, information about port forwarding and ddns (no-ip) in order to acces the esp8266 from outside my local network (from internet).
I don't want to enter in the router configuration to set port forwarding and ddns manually, i want it to be done automatically after connection with my router.
Any idea will be helpful,
Thank you!
