By mr rishu
#87805 I'm trying to update nodemcu from a password protected server. i can login from the nodemcu through basic http authentication (getting http code 200) but when trying to update the firmware its showing
HTTP_UPDATE_FAILD Error (-104): Wrong HTTP CODE
i'm using the code mentioned below
#include <ESP8266HTTPClient.h>
#include "base64.h"
#include <ESP8266httpUpdate.h>
const char* ssid = "ssid";
const char* password =  "pass";
String authUsername = "username";
String authPassword = "password";
  WiFi.begin(ssid, password);
    delay(1000);
    Serial.println("Connecting to WiFi..");
  Serial.println("Connected to WiFi");
  if ((WiFi.status() == WL_CONNECTED)) { //Check the current connection status
    HTTPClient http;
    http.begin("server");
    String auth = base64::encode(authUsername + ":" + authPassword);
    http.addHeader("Authorization", "Basic " + auth);
    //http.setAuthorization("auth");
    int httpCode = http.GET();
    if (httpCode > 0) { //Check for the returning code
        String payload = http.getString();
        Serial.println(httpCode);
        Serial.println(payload);
    else {
      Serial.println("Error on HTTP request");
    if (httpCode == 200)
      t_httpUpdate_return ret = ESPhttpUpdate.update("server/file.bin");
       switch (ret)
      case HTTP_UPDATE_FAILED:
      Serial.printf("HTTP_UPDATE_FAILD Error (%d): %s\n", ESPhttpUpdate.getLastError(), ESPhttpUpdate.getLastErrorString().c_str());
      break;
      case HTTP_UPDATE_NO_UPDATES:
      Serial.println("HTTP_UPDATE_NO_UPDATES");
      break;
      case HTTP_UPDATE_OK:
      Serial.println("HTTP_UPDATE_OK");
      break;
    http.end();
  delay(10000);
i'm new to this coding community, any help from the experts would appreciated.
