schufti wrote:> I still want to use the serial.print commend with the USB, for the debug process.
then no, as the usb/serial converter is wired to these pins ...
OK, makes sense. Yet still I wonder: Can I reroute the TX/RX to other GPIOs?
Explore... Chat... Share...
I assume the pins are not connected (i.e left side D1 is not hard wired to right side D1 ?)
