By Inq720
#93867 Ah... It's most likely wiring, and I may be blind, but I don't see the schematic or a simple picture would suffice.
You must be using an ESP-01 to have to jump through all those hoops. WeMos or NodeMCU are your friend or if you really need to use the ESP-01, I highly recommend the little programmers. :D
Als
