By MrMU
#70172 In the datasheet for the ESP8266 (0a-esp8266ex_datasheet_en.pdf) I see that by changing the WIFI standard between b/g/n the output power is changed.
The speed of transmission is not my first concern, but I want to extend the range.
So these figures out of the datasheet tells me that if I change the standard to B, I will get the most power.
Tx Power
802.11 b: +20 dBm
802.11 g: +17 dBm
802.11 n: +14 dBm
Rx Sensitivity
802.11 b: -91 dbm (11 Mbps)
802.11 g: -75 dbm (54 Mbps)
802.11 n: -72 dbm (MCS7)
Can I change these settings in the Arduino sketch?
By rudy
#70177 Put this at the top of the sketch.
extern "C" {
#include "user_interface.h"
Then this to change the setting, typically in setup but it depends on what you are doing.
wifi_set_phy_mode(PHY_MODE_11B)
Let us know how you make out. I'm also often interested in greater range over speed. While what you posted sure makes it look like B is a winner, N is typically claimed to have greater range.
Code: Select allName            Speed    Indoor Range
Wireless AC      1 Gbps      115 Feet
Wireless N     300 Mbps      230 Feet
Wireless G      54 Mbps      125 Feet
Wireless B      11 Mbps      115 Feet
By MrMU
#70197
rudy wrote:Put this at the top of the sketch.
extern "C" {
Thank you!!
If I do this:
Code: Select all#include <DHT.h>
#include <DHT_U.h>
#include "espipswitchtoggle.h"
extern "C" {
const char* ssid = "MySSID";
const char* password = "Mypasssssss";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
unsigned long timer = 0;
unsigned long firstMillis = 0;
  delay(10);
  pinMode(0, OUTPUT);
  pinMode(2,INPUT);
  pinMode(2, INPUT_PULLUP);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.softAP(ssid, password);
  Serial.print("AP IP address: ");
  Serial.println(myIP);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
  WIFI_set_phy_mode(PHY_MODE_11B);
I get this error during compiling:
exit status 1
'WIFI_set_phy_mode' was not declared in this scope
