i use library
https://github.com/esp8266/Arduino/tree ... it_ILI9341
Uses HSPI.
Wiring:
ILI9341 pin ESP-07 pin
MISO GPIO12
MOSI GPIO13
SCK GPIO14
CS GPIO15
DC GPIO2
Reset 3V3
only white screen not working.
Explore... Chat... Share...
Ribeiro Santos wrote:In your wiring is missing connect the TFT LED pin (through 50-60 Ohm resistor to 3V3), no?
In my case, I have to connect 5V to work.
