- Fri Oct 23, 2015 12:32 pm
#32133
Ray, thanks.
Couple of issues with that code and ESP8266WiFi.h. I down to this last one. I pasted in the code and used red on the offending line items.
Appreciate any help.
I never ask the same question twice.
Compile error.
Build options changed, rebuilding all
In file included from C:\Users\IBM_ADMIN\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:32:0,
from Email_Sender2.ino:5:
C:\Users\IBM_ADMIN\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&) [with T = char [64]; size_t = unsigned int]':
Email_Sender2.ino:88:20: required from here
C:\Users\IBM_ADMIN\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src/WiFiClient.h:73:28: error: request for member 'available' in 'src', which is of non-class type 'char [64]'
while (src.available() > 1460){
Code: Select all/*
Email client sketch for WiFi shield
Posted 29 May 2015 by SurferTim
#include <SPI.h>
WiFiClient client;
const char* ssid = "XXXXXX"; // Change to the name of your network
const char* password = "XXXXX"; // Change to your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
// change server to your email server ip or domain
//IPAddress server( n,n,n,n ); use this or next line 1 or the other not both
char server[] = "mail.yoursmtp.com"; //Change to your smtp server
int port = 2525; // this port for smtp2go
void setup()
delay(2000);
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println(F("WiFi shield not present"));
// don't continue:
while(true);
// check firmware version
// Serial.print(F("Firmware version: ")); did not have firmmware function.
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print(F("Attempting to connect to open SSID: "));
Serial.println(ssid);
status = WiFi.begin(ssid,password);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.print(F("You're connected to the network"));
printCurrentNet();
printWifiData();
delay(2000);
Serial.println(F("Ready. Press 'e' to send."));
void loop()
byte inChar;
inChar = Serial.read();
if(inChar == 'e')
if(sendEmail()) Serial.println(F("Email sent"));
else Serial.println(F("Email failed"));
byte sendEmail()
byte thisByte = 0;
byte respCode;
[u][b][color=#FF0000] char tBuf[64];[/color][/b][/u]
if(client.connect(server,port) == 1) {
Serial.println(F("connected"));
} else {
client.stop();
Serial.println(F("connection failed"));
return 0;
if(!eRcv()) return 0;
Serial.println(F("Sending hello"));
// change to the IP of your Arduino
strcpy_P(tBuf,PSTR("Hello n.n.n.n\r\n")); // your wifi ip
client.write(tBuf);
Serial.println(F("Sending auth login"));
strcpy_P(tBuf,PSTR("auth login\r\n"));
client.write(tBuf);
Serial.println(F("Sending User"));
strcpy_P(tBuf,PSTR("xxxxxxxxxxx\r\n")); // your smtp2go email id
client.write(tBuf);
Serial.println(F("Sending Password"));
strcpy_P(tBuf,PSTR("xxxxxxxx=\r\n")); // your smtp2go password
client.write(tBuf);
// change to your email address (sender)
Serial.println(F("Sending From"));
strcpy_P(tBuf,PSTR("MAIL From: <sender>\r\n")); / enter sender email
client.write(tBuf);
// change to recipient address
Serial.println(F("Sending To"));
strcpy_P(tBuf,PSTR("RCPT To: <receivert>\r\n")); // enter reciepient eamil
client.write(tBuf);
Serial.println(F("Sending DATA"));
strcpy_P(tBuf,PSTR("DATA\r\n"));
client.write(tBuf);
Serial.println(F("Sending email"));
strcpy_P(tBuf,PSTR("To: receiver email>\r\n")); // enter reciepient eamil
client.write(tBuf);
// change to your address
strcpy_P(tBuf,PSTR("From: Your Name <sender email>\r\n")); // enter sender email
client.write(tBuf);
client.println("Subject: Arduino email test\r\n");
client.println("This is from my Arduino!");
client.println(".");
Serial.println(F("Sending QUIT"));
strcpy_P(tBuf,PSTR("QUIT\r\n"));
client.write(tBuf);
client.stop();
Serial.println(F("disconnected"));
return 1;
byte eRcv()
byte respCode;
byte thisByte;
int loopCount = 0;
while(!client.available()) {
delay(1);
loopCount++;
// if nothing received for 10 seconds, timeout
if(loopCount > 10000) {
client.stop();
Serial.println(F("\r\nTimeout"));
return 0;
respCode = client.peek();
while(client.available())
thisByte = client.read();
Serial.write(thisByte);
if(respCode >= '4')
efail();
return 0;
return 1;
void efail()
byte thisByte = 0;
int loopCount = 0;
client.println("QUIT");
delay(1);
loopCount++;
client.stop();
return;
client.stop();
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print(F("SSID: "));
Serial.println(WiFi.SSID());
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print(F("signal strength (RSSI):"));
Serial.println(rssi);
// print the encryption type:
//byte encryption = WiFi.encryptionType(); // does not like this function
// Serial.print(F("Encryption Type:"));
// Serial.println(encryption,HEX);
void printWifiData() {
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print(F("IP Address: "));
Serial.println(ip);
Serial.println(ip);
//did not have WiFi.BSSID function in ESP8266WiFi.h
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print(F("MAC address: "));
Serial.print(mac[5],HEX);
Serial.print(F(":"));
Serial.print(mac[4],HEX);
Serial.print(mac[3],HEX);
Serial.print(mac[2],HEX);
Serial.print(mac[1],HEX);
Serial.println(mac[0],HEX);
// print your subnet mask:
IPAddress subnet = WiFi.subnetMask();
Serial.print(F("NetMask: "));
Serial.println(subnet);
// print your gateway address:
IPAddress gateway = WiFi.gatewayIP();
Serial.print(F("Gateway: "));
Serial.println(gateway);
