#include <DHT.h>
// replace with your channel’s thingspeak API key,
String apiKey = "sdfasdfasdfasdfasdf";
const char* ssid = "asdfasdf";
const char* password = "1231231231123123";
const char* server = "api.thingspeak.com";
#define DHTPIN 2 // what pin we’re connected to
DHT dht(DHTPIN, DHT11,15);
WiFiClient client;
// Required for LIGHT_SLEEP_T delay mode
extern "C" {
#include "user_interface.h"
void fpm_wakup_cb_func1(void) {
wifi_fpm_close(); // disable force sleep function
void sleepNow(int MILI) {
// Serial.println("Going to sleep...");
wifi_fpm_set_sleep_type(LIGHT_SLEEP_T); // light sleep
wifi_fpm_open(); // enable force sleep
wifi_fpm_set_wakeup_cb(fpm_wakup_cb_func1); // Set wakeup callback
wifi_fpm_do_sleep(MILI * 1000);
delay(MILI + 10);
delay(10);
dht.begin();
WiFi.mode(WIFI_STA); // Station Mode
WiFi.begin(ssid, password);
Serial.println(ssid);
Serial.print(".");
Serial.println("");
sleepNow(180000); // ca. 4 Min.???
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
return;
if (client.connect(server,80)) { // "184.106.153.149" or api.thingspeak.com
String postStr = apiKey;
postStr +="&field1=";
postStr += String(t);
postStr +="&field2=";
postStr += String(h);
postStr += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: "+apiKey+"\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" degrees Celcius Humidity: ");
Serial.print(h);
Serial.println("% send to Thingspeak");
client.stop();
Serial.println("Waiting…");
// thingspeak needs minimum 15 sec delay between updates
//delay(900000);
Question:
For my unterstanding, sleepNow(180) would mean an delay of 3 Minutes. In fact, 180000 actually is about 4 Minutes? At least that´s the time Thingspeak receives an update from DHT/ESP.
What to do to get an Delay of 15 Min. or more? With higher MILI-Values the script stops working.
Thanks!
PS: Script running...will see how long it lasts
